I have built a web-map using this sample code and I cannot figure out why the TOC doesn't work in my webmap. The Legend loads properly but the TOC with checkboxes does not. Here's my code. What am I missing?<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Cardno Web-Mapping</title>
<!-- Add ESRI style -->
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
<!-- Add Custom style -->
<link rel="stylesheet" type="text/css" href="cardno.css">
<!-- Required for dijits -->
<script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
<!-- Add ESRI Javascript API -->
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
// Add Dojo elements
dojo.require("dijit.dijit");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.AccordionContainer");
dojo.require("dijit.TitlePane");
dojo.require("dojo.parser");
dojo.require("esri.map");
dojo.require("esri.dijit.Legend");
dojo.require("esri.dijit.Measurement");
dojo.require("esri.SnappingManager");
dojo.require("esri.arcgis.utils");
dojo.require("dijit.form.CheckBox");
var map;
var legendLayers = [];
function init() {
// Set initial extent
var startExtent = new esri.geometry.Extent(-115.489, 42.973, -115.317, 43.066, new esri.SpatialReference({wkid:4326}) );
// Create map
map = new esri.Map("map", { extent: startExtent });
// Add base layer
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer");
map.addLayer(basemap);
// Setup Dynamic layer
var projLayers = new esri.layers.ArcGISDynamicMapServiceLayer("http://map.entrix.com/ArcGIS/rest/services/IdahoWind/IdahoWind/MapServer",{id:'proj'});
// Push layers to Legend
legendLayers.push({layer:projLayers,title:'Project Data'});
// Add Legend
dojo.connect(map,'onLayersAddResult',function(results){
var legend = new esri.dijit.Legend({
map:map,
layerInfos:legendLayers
},"legendDiv");
legend.startup();
// Add layers to map
map.addLayers([projLayers]);
// Add checkboxes
dojo.forEach(legendLayers,function(layer){
var layerName = layer.title;
var checkBox = new dijit.form.CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible,
onChange: function(evt) {
var clayer = map.getLayer(this.value);
clayer.setVisibility(!clayer.visible);
this.checked = clayer.visible;
//add the check box and label to the toc
dojo.place(checkBox.domNode,dojo.byId("toggle"),"after");
var checkLabel = dojo.create('label',{'for':checkBox.name, innerHTML:layerName},checkBox.domNode,"after");
dojo.place("<br />",checkLabel,"after");
// Add Measurement Widget
var measurement = new esri.dijit.Measurement({
map: map
}, dojo.byId('measurementDiv'));
measurement.startup();
dojo.connect(map, 'onLoad', function(theMap) {
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<div dojoType="dijit.layout.BorderContainer" design="headline" style="width: 100%; height: 100%;">
<div dojotype="dijit.layout.ContentPane" region="top">
<span>
This is the header section
</span>
</div>
<div id="leftPane" dojotype="dijit.layout.ContentPane" region="left" style="width: 300px;">
<div dojoType="dijit.layout.AccordionContainer">
<div dojoType="dijit.layout.ContentPane" id="legendPane" title="Legend" selected="true">
<div id="legendDiv"></div>
</div>
<div dojoType="dijit.layout.ContentPane" title="Natural Disasters" >
<span style="padding:10px 0;">Click to toggle the visibilty of the various natural disasters</span>
</div>
<div id="toggle" style="padding: 2px 2px;"></div>
</div>
</div>
<div dojotype="dijit.layout.ContentPane" region="center">
<div id="map"></div>
</div>
<div dojotype="dijit.layout.ContentPane" region="right" style="width: 100px;">
This is the right section
</div>
<div dojotype="dijit.layout.ContentPane" region="bottom">
This is the bottom section
</div>
</div>
</body>
</html>
