Hi Gary,
I am facing the same problem. 10.3 Feature Service and Map Service published from same mxd with subtypes defined for some layers. In map service everything is OK, but in feature service Type ID field is blank. Any suggestions?
Same problem, Type ID Field in the Feature Services is blank but populated in the Map Service. This makes the subtype field useless for an editing scenario.
I'm using Desktop and Server 10.3.
Gary, all fields are visible in the mxd and in my Portal map and the mxd only contains this one single subtyped feature class.
Hi NIcholas,
Did you change default layer symbology based on subtype field?
Mladen
Yes I did, I changed it to a single symbol. Changing it back to unique values based on the subtype field fixed it. Thank you!
