You didn't mention if you are using vector or raster data, but I will give a solution for vector data, because that is the most likely way that rivers and roads are digitized. You also didn't explain how you want your final values to be calculated. Adding all the risk values to get a possible result of 80, with protected areas having value 2 is my best guess. The other important clarification, is what feature are you trying to get risk values for? A larger analysis area polygon that contains all your other features perhaps?
1. Multiple ring buffer from your roads. Each ring should have the appropriate value from 1-32.
2. Multiple ring buffer from rivers. Each ring should have the appropriate value from 1-16.
3. Union of both buffer layers. Now you should have fields for both the river and road risk values in your result.
4. Use the identity tool; your input features is your analysis area polygon, your identity features is the union.
5. Identity of analysis area polygon with protected areas. Your input features is the analysis area polygon, your identity features is the protected areas.
6. Identity of analysis area polygon with deforestation density layer (you may have to convert this to polygons first). your input features is the analysis area polygon, your identity features is the deforestation density.
7. Add a field called risk. Calculate the field by adding the three fields from your roads, rivers, and deforestation risk together in the field calculator.
8. Select by attribute where the protected area FID <> -1. Calculate the risk field to 2.
Jodie Parkes, if this raises more questions, let me know. This should be a fairly easy process as long as you have defined the problem correctly, and you have all the necessary data layers.
Hi Monica,
Have you had any luck with this task? I am looking in to risk mapping at the moment and am trying to find the best way to get started.
Jodie
