It's not that these coordinate aren't 10200. They're just located very close to 0°N, 0°W
By the way, your previous script (received 2 days ago) works, but the 1 you posted today does not. I just wonder why the polyline2 could not be drawn. Thanks.
var testPoint = new Point(201394.01178484457, 173661.08635829584, new SpatialReference({wkid:26973}));
var polylineJson2 = { "paths":[[[201394.01178484457,173661.08635829584],[201392.0117168416,173661.08690949593],[ 201388.01158083565, 173661.08801189612 ],[ 201386.01151283266, 173661.08856309619 ],[ 201384.0114448297, 173661.08911429628 ],[ 201382.0113768267, 173661.08966549637 ],[ 201380.01130882374, 173661.09021669647 ],[ 201378.01124082075, 173661.09076789653 ] ] ],"spatialReference":{"wkid":102100} };
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no"> <title>Build your first application</title> <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style type="text/css"> html, body, #map { padding: 0; margin: 0; height: 100%; } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; require(["esri/map", "dojo/ready", "dojo/on", "esri/geometry/Polyline", "esri/graphic", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleMarkerSymbol", "esri/SpatialReference", "esri/geometry/Point", "dojo/domReady!"], function(Map, ready, on, Polyline, Graphic, SimpleLineSymbol, SimpleMarkerSymbol, SpatialReference, Point) { var map = new Map("map", { center: [-122.58, 45.55], //longitude, latitude zoom: 3, basemap: "streets", slider: true, //default sliderPosition: "top-left" //default }); ready(function (){ on(map, "load", drawPath); on(map, "click", function(evt){ if (evt.graphic) { console.log("Graphic Object:", evt.graphic); console.log("Spatial Reference Object:", evt.graphic.geometry.spatialReference); console.log("type:", evt.graphic.geometry.type); console.log("wkid:", evt.graphic.geometry.spatialReference.wkid); console.log("X:", evt.graphic.geometry.x); console.log("Y:", evt.graphic.geometry.y); } }); function drawPath(){ var polylineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 3); var polylineJson = { "paths":[[[-122.68,45.53], [-122.58,45.55], [-122.57,45.58],[-122.53,45.6]]], "spatialReference":{"wkid":4326}}; var polyline = new Polyline(polylineJson); var polylineGraphic = new Graphic(polyline, polylineSymbol, null, null); map.graphics.add(polylineGraphic); var pSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CIRCLE).setColor("#FFFF00"); var pnt = new Point(-122.58, 45.55, new SpatialReference(4326)); var pointGraphic = new Graphic (pnt, pSymbol); map.graphics.add(pointGraphic); try{ var testSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CIRCLE).setColor("#FF0000"); var testPoint = new Point(201394.01178484457, 173661.08635829584, new SpatialReference({wkid:26973}); var testGraphic = new Graphic (testPoint, testSymbol); map.graphics.add(testGraphic); }catch(e){ console.log(e); } } }); }); </script> </head> <body class="claro"></body> </html>
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no"> <title>Build your first application</title> <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style type="text/css"> html, body, #map { padding: 0; margin: 0; height: 100%; } #HomeButton { position: absolute; top: 95px; left: 20px; z-index: 50; } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; require([ "esri/map", "esri/dijit/HomeButton", "dojo/ready", "dojo/on", "esri/geometry/Polyline", "esri/geometry/Extent", "esri/graphic", "esri/symbols/SimpleLineSymbol", "dojo/domReady!" ], function( Map, HomeButton, ready, on, Polyline, Extent, Graphic, SimpleLineSymbol ) { //var ext = new Extent({ xmin: -8614312, ymin: 4687051, xmax: -8536040, ymax: 4730894, spatialReference: { wkid: 102100} }); var map = new Map("map", { basemap: "streets", zoom: 11, center: [-122.67, 45.54]}); var home = new HomeButton({map: map}, "HomeButton"); home.startup(); window.map = map; ready(function (){ on(map, "load", drawPath); function drawPath(){ var polylineJson1 = { "paths":[[[-122.68,45.53], [-122.58,45.55], [-122.57,45.58],[-122.53,45.6]]], "spatialReference":{"wkid":4326}}; var polylineJson2 = { "paths":[[[-122.68,45.53], [-122.58,45.55], [-122.57,45.58],[-122.53,45.6]]], "spatialReference":{"wkid":4326}}; var polyline1 = new Polyline(polylineJson1); var polyline2 = new Polyline(polylineJson2); var polylineSymbolRed = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 9); var polylineSymbolBlue = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,0,255]), 3); var redLine = new Graphic(polyline1, polylineSymbolRed, null, null); var blueLine = new Graphic(polyline2, polylineSymbolBlue, null, null); map.graphics.add(redLine); map.graphics.add(blueLine); } }); }); </script> </head> <body class="claro"> <div id="map"> <div id="HomeButton"></div> </div> </body> </html>
The "..." means more data. There are hundreds of pairs. You can eliminate the "..." and test others only. Thank.var polylineJson = { 'paths': [ [[201394.01178484457,173661.08635829584],[201392.0117168416,173661.08690949593], [ 201388.01158083565, 173661.08801189612 ], [ 201386.01151283266, 173661.08856309619 ], [ 201384.0114448297, 173661.08911429628 ], [ 201382.0113768267, 173661.08966549637 ], [ 201380.01130882374, 173661.09021669647 ], [ 201378.01124082075, 173661.09076789653 ]] ] };
Data are like that: var polylineJson = { 'paths': [ [ [ 201394.01178484457, 173661.08635829584 ], [ 201392.0117168416, 173661.08690949593 ], [ 201390.01164883861, 173661.08746069603 ], ... ] ] };Thanks.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no"> <title>Build your first application</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css" /> <style type="text/css"> html, body, #map { padding: 0; margin: 0; height: 100%; } </style> <script src="http://js.arcgis.com/3.7/"></script> <script> var map; require(["esri/map", "dojo/ready", "dojo/on", "esri/geometry/Polyline", "esri/graphic", "esri/symbols/SimpleLineSymbol", "dojo/domReady!"], function(Map, ready, on, Polyline, Graphic, SimpleLineSymbol) { var map = new Map("map", { center: [-122.67, 45.54], //longitude, latitude zoom: 12, basemap: "streets", slider: true, //default sliderPosition: "top-left" //default }); ready(function (){ on(map, "load", drawPath); function drawPath(){ var polylineJson = { "paths":[[[-122.68,45.53], [-122.58,45.55], [-122.57,45.58],[-122.53,45.6]]], "spatialReference":{"wkid":4326}}; var polyline = new Polyline(polylineJson); var polylineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 3); var g = new Graphic(polyline, polylineSymbol, null, null); map.graphics.add(g); } }); }); </script> </head> <body class="claro"> <div id="map"></div> </body> </html>
map.graphics.add(new esri.Graphic(polyline, polylineSymbol, null, null));
