We have an environment with Portal 10.5
We need to install the latest Operations dashboard
We don’t want to upgrade the portal, we just want a way to have the latest operations dashboard on Portal 10.5
Is there a solution for this?
Thank you
Hi Ali,
> We have an environment with Portal 10.5. We need to install the latest Operations dashboard. We don’t want to upgrade the portal, we just want a way to have the latest operations dashboard on Portal 10.5. Is there a solution for this?
Unfortunately, the answer is "no, we don't have a solution". Portal for ArcGIS 10.5 was released before the web-browser based Operations Dashboard for ArcGIS was released. The internal content directory of Portal 10.5 does not have a "Dashboard" item in its schema, which is what Operations Dashboard uses. There's also no Operations Dashboard installer available for Portal 10.5. Sorry.
You will have to upgrade to Portal for ArcGIS 10.6 or later to use the web-browser based Operations Dashboard for ArcGIS.
Hope this helps,
