I have a shared node need to be moved using map topology.
But when I move the node, all other segments also move together.
I just want the node to be moved.
Any helps?
I solve it. I forgot to uncheck the Stretch topology proportionately when moving a topology element option in Editing Options window. Thank you.
Yes. I am using Topology Edit tool on the Topology toolbar. But then which tool in Edit Vertices toolbar should I use to just move the shared vertex?
Are you using these tools modifying-a-topology-edge If the vertex are shared, then all elements connected to it will be affected. Check the other options on the Edit Vertices toolbar
