I have some code that will allow a user to geocode two addresses. It will display the points of the addresses on the map.
I want to then set the extent of the map to the two points. To accomplish this I get the x and y coordinates of both points, create a polyline, get and set the extent of the polyline as the new extent of the map.
The problem is that the new extent is zoomed in a bit to far and you have to zoom out one level to see the points.
To get around this i thought I would be able to get the zoom level after the setExtent using the extent-change listener and add one to it to zoom the map out one level.
Problem is if I put the setZoom within the extent-change listener function, the code will get into a loop.
If I put the setZoom outside this function it is undefined.
Specifically the lines starting at 252 are in question.
I am not sure what else I can check or where else I can put the setZoom so that it does not get called until zoom is populated.
<SPAN class="comment token">/**
* Created by Student on 11/20/2014.
*/</SPAN>
<SPAN class="keyword token">var</SPAN> mapMain<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> fromXCoord<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> toXCoord<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> pLine<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> fPoint<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> tPoint<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> fromZone<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> toZone<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> fZone<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> tZone<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> numPass<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// @formatter:off</SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/webMercatorUtils"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/InfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/LabelClass"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/Scalebar"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/TextSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/renderers/UniqueValueRenderer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/Search"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/graphic"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Polyline"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/query"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/QueryTask"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/ready"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/promise/all"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/TitlePane"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/registry"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN>SpatialReference<SPAN class="punctuation token">,</SPAN>webMercatorUtils<SPAN class="punctuation token">,</SPAN>Extent<SPAN class="punctuation token">,</SPAN>InfoTemplate<SPAN class="punctuation token">,</SPAN>FeatureLayer<SPAN class="punctuation token">,</SPAN>LabelClass<SPAN class="punctuation token">,</SPAN>Scalebar<SPAN class="punctuation token">,</SPAN>SimpleFillSymbol<SPAN class="punctuation token">,</SPAN>SimpleLineSymbol<SPAN class="punctuation token">,</SPAN>SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN>TextSymbol<SPAN class="punctuation token">,</SPAN>Color<SPAN class="punctuation token">,</SPAN>SimpleRenderer<SPAN class="punctuation token">,</SPAN>UniqueValueRenderer<SPAN class="punctuation token">,</SPAN>
Search<SPAN class="punctuation token">,</SPAN>Graphic<SPAN class="punctuation token">,</SPAN>Polyline<SPAN class="punctuation token">,</SPAN>Point<SPAN class="punctuation token">,</SPAN>Query<SPAN class="punctuation token">,</SPAN>QueryTask<SPAN class="punctuation token">,</SPAN>
ready<SPAN class="punctuation token">,</SPAN> parser<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> all<SPAN class="punctuation token">,</SPAN>
BorderContainer<SPAN class="punctuation token">,</SPAN> ContentPane<SPAN class="punctuation token">,</SPAN> TitlePane<SPAN class="punctuation token">,</SPAN> registry
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// @formatter:on</SPAN>
<SPAN class="comment token">// Wait until DOM is ready *and* all outstanding require() calls have been resolved</SPAN>
<SPAN class="token function">ready</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Parse DOM nodes decorated with the data-dojo-type attribute</SPAN>
parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
* Step: Specify the initial extent
* Note: Exact coordinates may vary slightly from snippet/solution
*/</SPAN>
<SPAN class="keyword token">var</SPAN> extentInitial <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"xmin"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">74.0249340000041</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ymin"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">42.5025420000134</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"xmax"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">73.5927189999818</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ymax"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">43.1172190002567</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"spatialReference"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"wkid"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Create the map</SPAN>
mapMain <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"cpCenter"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
basemap <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"osm"</SPAN><SPAN class="punctuation token">,</SPAN>
extent <SPAN class="punctuation token">:</SPAN> extentInitial<SPAN class="punctuation token">,</SPAN>
showLabels <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
* Step: Add the taxi layer layer to the map
*/</SPAN>
<SPAN class="keyword token">var</SPAN> albTaxiLayerURL <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fservices2.arcgis.com%2FA3lMfLhXIUtyxP6p%2Farcgis%2Frest%2Fservices%2FCityOfAlbanyTaxi%2FFeatureServer%2F0" target="_blank">http://services2.arcgis.com/A3lMfLhXIUtyxP6p/arcgis/rest/services/CityOfAlbanyTaxi/FeatureServer/0</A><SPAN>"</SPAN></SPAN>
<SPAN class="comment token">//Step: Specify the output fields.</SPAN>
<SPAN class="keyword token">var</SPAN> taxiOutFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Zone"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Fare"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Template for popup when user clicks a zone.</SPAN>
<SPAN class="keyword token">var</SPAN> taxiTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
taxiTemplate<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setTitle</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"</br><tr><td><b>Zone: ${Zone}</b></tr></td>"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
taxiTemplate<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"<tr><b>Fare: $</b><td>${Fare}</td></tr></br>"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Construct the taxi layer</SPAN>
<SPAN class="keyword token">var</SPAN> taxiLyr <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>albTaxiLayerURL<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
infoTemplate <SPAN class="punctuation token">:</SPAN> taxiTemplate<SPAN class="punctuation token">,</SPAN>
outFields <SPAN class="punctuation token">:</SPAN> taxiOutFields<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">var</SPAN> defStyle <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_NULL<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">215</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">252</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">216</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//This section crate the thematic to color code each zone</SPAN>
<SPAN class="keyword token">var</SPAN> renderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">UniqueValueRenderer</SPAN><SPAN class="punctuation token">(</SPAN>defStyle<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Zone"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//add symbol for each possible value</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"A"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_NULL<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">49</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">70</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">140</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="number token">25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"B"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_NULL<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">159</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">188</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">245</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="number token">25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"C"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_NULL<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">135</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">59</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">92</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="number token">25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"D"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_NULL<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">68</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">135</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">108</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="number token">25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"E"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_NULL<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">245</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">95</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">235</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="number token">25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"F"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_NULL<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">227</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">117</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">84</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="number token">25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"G"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_NULL<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">232</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">245</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">115</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="number token">25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"X"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">232</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">245</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">115</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
taxiLyr<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>renderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create a text symbol to define the style of labels</SPAN>
<SPAN class="keyword token">var</SPAN> labelColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#666"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> zoneLabel <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TextSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setColor</SPAN><SPAN class="punctuation token">(</SPAN>labelColor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
zoneLabel<SPAN class="punctuation token">.</SPAN>font<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"14pt"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
zoneLabel<SPAN class="punctuation token">.</SPAN>font<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setFamily</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"arial"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> json <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"labelExpressionInfo"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"value"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"{Zone}"</SPAN><SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//create instance of LabelClass (note: multiple LabelClasses can be passed in as an array)</SPAN>
<SPAN class="keyword token">var</SPAN> labelClass <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LabelClass</SPAN><SPAN class="punctuation token">(</SPAN>json<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
labelClass<SPAN class="punctuation token">.</SPAN>symbol <SPAN class="operator token">=</SPAN> zoneLabel<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// symbol also can be set in LabelClass' json</SPAN>
taxiLyr<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setLabelingInfo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> labelClass <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>taxiLyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">centerAndZoom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">73.769879</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">42.662037</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">12</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
* Step: Add the scalebar widget to the map
*/</SPAN>
<SPAN class="keyword token">var</SPAN> scalebar <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Scalebar</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> mapMain<SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">// "dual" displays both miles and kilmometers</SPAN>
<SPAN class="comment token">// "english" is the default, which displays miles</SPAN>
<SPAN class="comment token">// use "metric" for kilometers</SPAN>
scalebarUnit<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"dual"</SPAN>
<SPAN class="comment token">//from address geocoder</SPAN>
<SPAN class="keyword token">var</SPAN> fromSearch <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
enableLabel<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
enableInfoWindow<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
autoNavigate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
fromSearch<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//to address geocoder</SPAN>
<SPAN class="keyword token">var</SPAN> toSearch <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
toSearch<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dijit<SPAN class="punctuation token">.</SPAN>registry<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"goButton"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> doSearchValue<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">doSearchValue</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> fromAddress <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"fromAddr"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value
<SPAN class="comment token">//alert(fromAddress);</SPAN>
<SPAN class="comment token">//highlight symbol</SPAN>
fromGeocodeSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
SimpleMarkerSymbol<SPAN class="punctuation token">.</SPAN>STYLE_CIRCLE<SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">20</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">85</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">82</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">82</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">10</SPAN>
<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">76</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">230</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.9</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
fromSearch<SPAN class="punctuation token">.</SPAN>sources<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>highlightSymbol <SPAN class="operator token">=</SPAN> fromGeocodeSymbol<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//set the symbol for the highlighted symbol</SPAN>
fromSearch<SPAN class="punctuation token">.</SPAN><SPAN class="token function">search</SPAN><SPAN class="punctuation token">(</SPAN>fromAddress<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> toAddress <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"toAddr"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value
<SPAN class="comment token">//alert(toAddress);</SPAN>
<SPAN class="keyword token">var</SPAN> toGeocodeSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">245</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">29</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">29</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.9</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
toSearch<SPAN class="punctuation token">.</SPAN>sources<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>highlightSymbol <SPAN class="operator token">=</SPAN> toGeocodeSymbol<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//set the symbol for the highlighted symbol</SPAN>
<SPAN class="comment token">//If multiple results are found, it will default and select the first.</SPAN>
toSearch<SPAN class="punctuation token">.</SPAN><SPAN class="token function">search</SPAN><SPAN class="punctuation token">(</SPAN>toAddress<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//get coordinates of toAddress to pass to use to create polyline for zooming to extent. </SPAN>
fromSearch<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'select-result'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
fromWebCoords <SPAN class="operator token">=</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">webMercatorToGeographic</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">.</SPAN>result<SPAN class="punctuation token">.</SPAN>feature<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">getCoordsAndZoom</SPAN><SPAN class="punctuation token">(</SPAN>fromWebCoords<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"from"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
toSearch<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'select-result'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
toWebCoords <SPAN class="operator token">=</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">webMercatorToGeographic</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">.</SPAN>result<SPAN class="punctuation token">.</SPAN>feature<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">getCoordsAndZoom</SPAN><SPAN class="punctuation token">(</SPAN>toWebCoords<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"to"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getCoordsAndZoom</SPAN><SPAN class="punctuation token">(</SPAN>geoResults<SPAN class="punctuation token">,</SPAN> which<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>which <SPAN class="operator token">===</SPAN> <SPAN class="string token">"from"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
fromXCoord <SPAN class="operator token">=</SPAN> geoResults<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">;</SPAN>
fromYCoord <SPAN class="operator token">=</SPAN> geoResults<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">;</SPAN>
fPoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>fromXCoord<SPAN class="punctuation token">,</SPAN> fromYCoord<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//console.log("In checkResults from " + fromXCoord);</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN>
toXCoord <SPAN class="operator token">=</SPAN> geoResults<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">;</SPAN>
toYCoord <SPAN class="operator token">=</SPAN> geoResults<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">;</SPAN>
tPoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>toXCoord<SPAN class="punctuation token">,</SPAN> toYCoord<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>fromXCoord <SPAN class="operator token">&&</SPAN> fromYCoord <SPAN class="operator token">&&</SPAN> toXCoord <SPAN class="operator token">&&</SPAN> toYCoord<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> zoom<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Create polyline that will be used to zoom to the extent of both points that were geocoded</SPAN>
<SPAN class="keyword token">var</SPAN> pLine <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polyline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>wkid<SPAN class="punctuation token">:</SPAN><SPAN class="number token">4326</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
pLine<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addPath</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN>fromXCoord<SPAN class="punctuation token">,</SPAN> fromYCoord<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN>toXCoord<SPAN class="punctuation token">,</SPAN> toYCoord<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>pLine<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getExtent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'extent-change'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
zoom <SPAN class="operator token">=</SPAN> mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getZoom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>zoom<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setZoom</SPAN><SPAN class="punctuation token">(</SPAN>zoom<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
