Hello, we are using a very basic nginx proxy to do our API calls due to some old libraries being used in our code base and us needing something in the middle to do the job, this appears to work fine:
server {
listen 0.0.0.0:8080;
# server name must match vesper sys.config
access_log /var/log/nginx/a17-arcgis/timers.access.log timing;
access_log /var/log/nginx/a17-arcgis/access.log;
error_log /var/log/nginx/a17-arcgis/error.log notice;
location /arcgis/rest/services/World/GeocodeServer/findAddressCandidates {
proxy_pass https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/findAddressCandidates;
proxy_pass_request_headers on;
location /sharing/rest/oauth2/token {
proxy_pass https://www.arcgis.com/sharing/rest/oauth2/token/;
proxy_set_header Host $host;
I have a concern because I know the IP being used is part of AWS infrastructure, if it's an ELB the IP can change any time and our proxy will stop working.
If I instead change the proxy to use this format, it breaks on the token exchange and gives 404's despite a TCPDUMP showing it's resolving the host correctly, has anyone else had this issue / got any advice?
server {
resolver 172.32.0.2 valid=10s;
set $variable "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/findAddressCandidates";
proxy_pass $variable;
set $token "https://www.arcgis.com/sharing/rest/oauth2/token/";
proxy_pass $token;
I'm essentially trying to reduce the risk of an IP change breaking the proxy.
