Hi all,
I have received many .mdb files but I am not able to see them in GIS. If I import them into ArcGIS 10.2.2 I can see just the table. Does anyone know how can I convert these .mdb into useful info? (I mean like shapefiles or any other data that I can see with GIS).
Many thanks,
F
An mdb could be a Personal Geodatabase, but then you would see featureclasses inside if there were any. In case the tables have coordinates you can use XY events (Make XY Event Layer—Help | ArcGIS Desktop ) to create point featureclasses and if you have addresses you can geocode and create points.
What is supposed to be inside the mdb files? Any metadata or explanation provided when the files were handed in to you?
Hi, Francesca.
If it is an access database, you could create an OLE DB connection to the access table, and pull in the table. Then you could create a join to another feature class. Then export to a new file. I do not know if this would work in PRO.
Example I have used, is a ole db connection to an access table that contains all Variances in our city over the past 40 years... join it to an address table, and export it out as a new Variance file.
Allen
Hi FRANESCARUSSO22 , would it be possible to share a MDB file to validate if it really isn't a PGDB? Ted has a very good point that it could be ArcGIS Pro not recognizing the data.
DGN's also use the same fields
And secondly ArcGIS Pro cannot read a personal geodatabase!!!! <-- my issue with ArcGIS Pro!
I see you are using ArcGIS Pro. What is interesting is that the fields EntityType and EntityColor are the only numeric fields, but those fields are normally used by CAD drawing (lie DWG and DXF from AutoCAD). Maybe the mdb files correspond to CDA drawings with the geometries. Did you only receive mdb files or is there more?
Certainly when the data was provided to you something must have been said about what it contains.
Hi..
I think this is not a personal gdb. When I right click on the table in the TOA and do "Display x,y" I cannot see any value. (please see screenshot). If it is like it is I think there is not too much I can do..am I right? I do not even know what they are supposed to be as I cannot see any related data of them in the GIS package we received.
is your .mdb files are personal geodatabases? or Microsoft access database files, just having non spatial data/table?
if these mdb are personal geodatabases containing spatial data. you can directly read it from ArcGIS Desktop 10.2. on other hand, if your non spatial table contains XY coordinates of feature in a table, which you can import using "Add XY data" tool and export them as shape file.
