I need to end up with a series of line segments that are equal to the original line feature. I was looking to split the line at the midpoint between every two vertices(vertices every 0.1 feet) If that isn't possible I was wondering if I could split the line every 0.05 feet. I would then merge every 2 segments into 1 segment to get the result I need.
I'm looking for a way to split a line at the midpoint between two vertices. Or if I have a series of line segments, is there anyway to go down the line and merge every 2 segments together? I have a series of slope measurements on a road. Just splitting the segment at each vertex does not accurately reflect the data which was collected at each vertex. The vertex needs to be the midpoint of each line segment. It can be a script or a program, etc as long as it does the job. Thanks.
Hi Joe -Is there any chance the ArcGIS for Local Government - Address Management add-in has the tools you need? Maybe the Create Road and Split Intersecting Road tool? http://resources.arcgis.com/en/help/localgovernment/10.1/index.html#//028s00000073000000
Hi Joe -Is there any chance the ArcGIS for Local Government - Address Management add-in has the tools you need? Maybe the Create Road and Split Intersecting Road tool? http://resources.arcgis.com/en/help/localgovernment/10.1/index.html#//028s00000073000000If not, you might contact the Local Government folks or post your suggestion to the ArcGIS Ideas site: http://ideas.arcgis.com/idealist?c=09a300000004xET&category=local+government
There is a utility on the Editing Labs group on arcgis.com that will divide a line multiple times and leave a remainder. You can download the add-in from http://www.arcgis.com/home/item.html?id=d5d27ee47330434b9a96b91136a0118fOther Editing Labs tools for ArcGIS 10 (make sure the filter at the top of the page is Show: All Content, not Web Content Only):http://www.arcgis.com/home/group.html?owner=Doug&title=Editing%20Labs
