Hi, I would like to use my own TreeView style in the Legend control, however I can't seems to render the items at all, only the MapLayerTemplate is rendered. If i use the default style(without specifying Template property), it works fine. Here is the xaml for my Legend.Template property. (I got most of the xaml code from Blend's "Edit a Copy" function)
<esri:Legend.Template>
<ControlTemplate TargetType="{x:Type esri:Legend}">
<TreeView BorderBrush="{TemplateBinding BorderBrush}"
BorderThickness="{TemplateBinding BorderThickness}"
Background="{TemplateBinding Background}"
Foreground="{TemplateBinding Foreground}"
HorizontalContentAlignment="{TemplateBinding HorizontalContentAlignment}"
Padding="{TemplateBinding Padding}"
VerticalContentAlignment="{TemplateBinding VerticalContentAlignment}"
ItemsSource="{TemplateBinding LayerItemsSource}">
<TreeView.ItemTemplate>
<HierarchicalDataTemplate AlternationCount="0"
ItemBindingGroup="{x:Null}"
ItemTemplate="{x:Null}"
ItemContainerStyleSelector="{x:Null}"
ItemStringFormat="{x:Null}"
ItemsSource="{Binding LayerItemsSource}"
ItemContainerStyle="{x:Null}"
ItemTemplateSelector="{x:Null}">
<ContentPresenter ContentTemplate="{Binding Template}" Content="{Binding}"/>
</HierarchicalDataTemplate>
</TreeView.ItemTemplate>
<TreeView.ItemContainerStyle>
<Style TargetType="{x:Type TreeViewItem}">
<Setter Property="IsExpanded" Value="{Binding IsExpanded, Mode=TwoWay}"/>
<Setter Property="IsSelected" Value="{Binding IsSelected, Mode=TwoWay}"/>
</Style>
</TreeView.ItemContainerStyle>
<TreeView.Template>
<ControlTemplate TargetType="{x:Type TreeView}">
<s:SurfaceScrollViewer Background="{TemplateBinding Background}"
Style="{StaticResource VerticalSurfaceScrollViewerStyle}">
<ItemsPresenter/>
</s:SurfaceScrollViewer>
</ControlTemplate>
</TreeView.Template>
</TreeView>
</ControlTemplate>
</esri:Legend.Template>
