If you start looking under the hood at what mobileSync is doing through debugger- it basically ends up looping through each feature layer and calling a full featurelayersyncagent on each one.What you can do instead is loop through each feature layer, create a featurelayersync and set download direction and download filter. These greatly speeds up the sync process time.If you still do not see the new data- try calling a map refresh.You could also dive into your featurelayersynresult and see if any exceptions are occuring. I have found any exceptions that happen in the sync do not bubble up to the application. You have to wrtie code to check all the exceptions and if any display the error.
