Hi All,
I have been successful at modifying apps and hosting them via I.I.S.. However the same apps I have had working before and still work through developer edition on my computer will no longer get past the loading screen when published via IIS on our server. If I go back to a new unmodified app I.I.S. can host it without problem. So, some edit along the way breaks the "hostability" of my app. With the exception of one by one adding widgets and and republishing through IIS to see which one breaks the app, is there a good way to determine the problem?
Here is the chrome developer tools error result:
Failed to load resource: the server responded with a status of 404 (Not Found)
http://ncservgis-prod.xyz.local/http://ncservgis-prod.xyz.local//jsapi/jsapi/dijit/themes/claro/dojo.css
same error for claro.css, esri.css, ResizeHandle.css, init.js and they all show up in the list twice...
Thanks so much!
