Does anyone know if it is possible to trace a line in collector?
This would be slightly different than Trace Downstream, I may not even be asking the correct question
For example, Say I have a pipeline feature, and I want to change the coating between two points.
Could I position my begin and end points, and then select the between section to modify (essentially the tabular data)?
Paul
