I have no issue attaching a map to the survey when I am in the designer. When I publish, however, the map only shows white and when hovering over it says "Loading". It does this for an extended period of time too. Is there a setting I need to check for this function to work? The function does work in the Survey123 mobile application just not the desktop browser
