Whenever I try to delete a map from the catalog pane, ArcGIS Pro crashes even after removing all the layers. This happens on the first try on the second try it succeeds deleting the map.
Never seen that, which leave your profile and/or the location of your *.aprx and anything else you can provide about your environment
Just ran across this and it is happening every time I try to delete a data frame in the layout. EVERY TIME!!! No fix found yet.
What release of AGP are you using and do you have any Python scripts in the AGP project?
No Python scripts running. Pretty basic inset map in a data frame. Running Pro V. 2.3.0
Michael - did you submit the error report and include a valid email address? (See https://www.esri.com/arcgis-blog/products/arcgis-pro/announcements/arcgis-desktop-error-reporter-learns-its-manners/ for why this is very helpful).
I searched using your email and couldn't find a report, so I'm not sure what this crash is. Could you please send the latest .dmp file from C:\Users\<username>\AppData\Local\ESRI\ErrorReports?
That way we'll be able to see if there might already be an existing fix in one of the patches for 2.3 or in the current version of ArcGIS Pro 2.4.
Thank you!
What is the best way to send the files to you? because I am on Domain machine for the State of Idaho Military DIV either the error report fails to send or is under a different user name. I can send the .DMP files to you I think via email.
Thank you for looking into this,
Here are a few. One of the DMP files is 18kb and wont attach for some reason.
Michael Nau
Michael.s.nau2.mil_IDARNG
