First, thanks for your response. That was the way I was leaning too, but i didn't want to have hardcode a connection string. Since the MXD requires certain layers in the TOC I have access to the database, and planned on using the layers connection to gain access to the rest of the database.
Private Function GetConnectionString(ByVal paramServerName, ByVal paramDataBaseName) As String Return "Data Source=" & paramServerName & ";" _ & "Initial Catalog=" & "paramDataBaseName & "; Integrated Security=True;" End Function
I want to apologize for this next stupid question up front, but are you able to use the same connection string for an ADODB.Connection as you are for a SqlClient.SqlConnection or a IWorkspace connection? I was under the impression that they were all in different formats and were not interchangable.
Imports System.Data.Sql Imports System.Data.SqlClient Public Class vrConn Implements IDisposable Private disposedValue As Boolean = False Private _LastException As SqlException Private sqlCn As New SqlConnection() Public Sub New() MyBase.New() Me.openConnection(GetConnectionString) End Sub Public Property sqlConn() As SqlConnection Get Return sqlCn End Get Set(ByVal value As SqlConnection) sqlCn = value End Set End Property Public Overrides Function ToString() As String If Me.sqlCn Is Nothing Then Return "" Else Return Me.sqlCn.ToString End If End Function Public Sub openConnection(ByVal cnnString As String) If sqlCn.State <> ConnectionState.Open Then Try If Me.sqlCn Is Nothing Then Me.sqlCn = New SqlConnection End If sqlCn.ConnectionString = cnnString sqlCn.Open() Catch sqlEx As SqlException Me._LastException = sqlEx Catch ex As Exception MsgBox(ex.ToString) End Try End If End Sub Public Sub CloseConnection() If sqlCn.State = ConnectionState.Open Then sqlCn.Close() End If Me.Dispose() End Sub Private Function GetConnectionString() As String Return "Data Source=ServerName;" _ & "Initial Catalog=DataBaseName; Integrated Security=True;" End Function Public ReadOnly Property LastException() As SqlException Get Return _LastException End Get End Property Protected Overridable Sub Dispose(ByVal disposing As Boolean) If Not Me.disposedValue Then If disposing Then Me.sqlCn = Nothing GC.Collect() End If End If Me.disposedValue = True End Sub #Region " IDisposable Support " ' This code added by Visual Basic to correctly implement the disposable pattern. Public Sub Dispose() Implements IDisposable.Dispose ' Do not change this code. Put cleanup code in Dispose(ByVal disposing As Boolean) above. Dispose(True) GC.SuppressFinalize(Me) End Sub #End Region End Class
Imports System.Data.Sql Imports System.Data.SqlClient Private sqlCn As New SqlConnection() Private connSvc As vrConn Public Sub New() MyBase.New() connSvc = New vrConn sqlCn = connSvc.sqlConn End Sub 'Here is a funciton that fills a DataTable of "Species" via a Stored Procedure Public Function Hydrate_speciesList() As DataTable Dim spCmdSpec As SqlCommand = New SqlCommand() spCmdSpec.CommandText = "dbo.SpeciesSelect" spCmdSpec.CommandType = CommandType.StoredProcedure Dim ds As New DataSet() Dim da As New SqlDataAdapter Try Me.OpenConnection() Using spCmdSpec spCmdSpec.Connection = Me.sqlCn da.SelectCommand = spCmdSpec da.Fill(ds, "species") End Using Me.CloseConnection() Dim tb As DataTable = ds.Tables("species") tb.Rows.RemoveAt(0) Return tb Catch ex As Exception MsgBox(ex.ToString) Me.CloseConnection() Return Nothing End Try End Function 'database connectivity Private Sub CloseConnection() If sqlCn.State = ConnectionState.Open Then sqlCn.Close() End If End Sub Private Sub OpenConnection() If sqlCn.State = ConnectionState.Closed Then sqlCn.Open() End If End Sub
