"Applications targeting Silverlight version 3 can only bind to target properties of a FrameworkElement. Support for binding to any DependencyObject dependency property was added in Silverlight 4."It does not look like UserControl derives from FrameworkElement. See msdn documentation: http://msdn.microsoft.com/en-us/libr...tanceContinued
The following link shows someone with a similar problem and the workaround they used.http://betaforums.silverlight.net/fo...20/418564.aspx
<esri:Editor x:Key="MyBarriersEditor" LayerIDs="MyBarriersGraphicsLayer" Map="{Binding ElementName=MyMap}" />
Per your post, I should remove this piece of code and then use public Map Map {...}Is it right? If so, how can I define these graphicslayers? Thanks.
<local:ClosestFacilityControl x:Name="MyClosedFacility" Visibility="Collapsed" Height="240" Width="440" Canvas.Left="306" Canvas.Top="140" Map="{Binding ElementName=_Map}" />
public Map Map { get { return GetValue(MapProperty) as Map; } set { SetValue(MapProperty, value); } } public static readonly DependencyProperty MapProperty = DependencyProperty.Register("Map", typeof(Map), typeof(ClosestFacilityControl), new PropertyMetadata(OnMapPropertyChanged)); .......
<esri:Map x:Name="_Map" Background="White" Extent="-117.23,34.03,-117.16,34.08" > .... </esri:Map>
<esri:Editor x:Key="MyBarriersEditor" LayerIDs="MyBarriersGraphicsLayer" Map="{Binding ElementName=_Map}" />
<local:ClosestFacilityControl Map="{Binding ElementName=MyMap}" VerticalAlignment="Top" HorizontalAlignment="Center"/>
public Map Map { get { return GetValue(MapProperty) as Map; } set { SetValue(MapProperty, value); } } public static readonly DependencyProperty MapProperty = DependencyProperty.Register("Map", typeof(Map), typeof(ClosestFacilityControl), new PropertyMetadata(OnMapPropertyChanged)); private static void OnMapPropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) { ClosestFacilityControl control = d as ClosestFacilityControl; Map newMap = e.NewValue as Map; if(control!=null) { Editor editor = control.LayoutRoot.Resources["MyBarriersEditor"] as Editor; if(editor!=null) editor.Map = newMap; editor = control.LayoutRoot.Resources["MyFacilitiesEditor"] as Editor; if(editor!=null) editor.Map = newMap; editor = control.LayoutRoot.Resources["MyIncidentsEditor"] as Editor; if(editor!=null) editor.Map = newMap; control.facilitiesGraphicsLayer = newMap.Layers["MyFacilitiesGraphicsLayer"] as GraphicsLayer; control.IncidentsGraphicsLayer = newMap.Layers["MyIncidentsGraphicsLayer"] as GraphicsLayer; control.barriersGraphicsLayer = newMap.Layers["MyBarriersGraphicsLayer"] as GraphicsLayer; control.routeGraphicsLayer = newMap.Layers["MyRoutesGraphicsLayer"] as GraphicsLayer; } }
