There is a tool called Export Feature Attribute to ASCII that I just tried for the first time a moment ago. You might look at that, and then see if you can figure out a way to automate importing that into access. Certainly you could import it manually...Good Luck!
Joe- That does help a little bit. I already have an odbc connection to the access database. I actually use it in a model to geocode the addresses and output to a file geodatabase. I can't figure out how to geocode back to teh access database. Is there any documentation on that? Does it matter that I am using an access 2007 accdb?
So i have roughly 500K policies that I geocode monthly from an access database. The access database is populated from a Microstrategy report as I do not have direct access to the policy server. Most of the policies have previously been geocoded. The geocoded results are currently saved in a file geodatabase. I would like to create a workflow where I would only have to geocode new policies and not all policies every month.Any ideas? Can ArcCatalog geocode back to an access database?PS. I only have an ArcView license.Thanks in advance.
