ArcGIS API is providing a way to generate heat map based on ArcGIS Services like this one at This Example.
Is there any way to generate the heat map based on actual point values on the fly instead of using a service URL. I mean if I have a data like
<SPAN class="keyword token">var</SPAN> data <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="punctuation token">{</SPAN>
x<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">13625078.0408</SPAN>
y<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4548494.332400002</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
is there any way to pass it as Service URL at `heatmapFeatureLayerOptions` like
<SPAN class="keyword token">var</SPAN> heatmapFeatureLayerOptions <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
mode<SPAN class="punctuation token">:</SPAN> data<SPAN class="punctuation token">.</SPAN>MODE_SNAPSHOT<SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>Thanks
