I am trying to upgrade my flex application to 3.1 and am having problems with the eSearch widget. I have a multiple expression search that worked fine at 2.5. When I upgraded to 3.1 and the newest eSearch widget the multiple expression automatically runs when I fill in the first value and I never have the oppurtunity to select the second value. I have tried all different combinations of isvaluerequired, all with the same result. Below is the config for this particular expression. Any help would be appreciated.<expression alias="Tie Lines" textsearchlabel="Select TO's to display tie lines..." isvaluerequired="true"> <values> <value prompt="Select Area..." isvaluerequired="true" userlist="AECI,AEPW,AMMO,CLEC,EES,EMDE,GMO,GRDA,INDN,KACY,KCPL,LAFA,LAGN,LEPA,LES,MEC,MIDW,NPPD,OKGE,OMPA,OPPD,SPRM,SPS,SUNC,SWPA,WAPA,WERE,WFEC"> UPPER(SDE.SPP_TIE_LINES.TIE_NAM) LIKE UPPER('%[value]%')</value> <value prompt="Select Area..." isvaluerequired="true" userlist="AECI,AEPW,AMMO,CLEC,EES,EMDE,GMO,GRDA,INDN,KACY,KCPL,LAFA,LAGN,LEPA,LES,MEC,MIDW,NPPD,OKGE,OMPA,OPPD,SPRM,SPS,SUNC,SWPA,WAPA,WERE,WFEC" operator="AND"> UPPER(SDE.SPP_TIE_LINES.TIE_NAM) LIKE UPPER('%[value]%')</value> </values> </expression>
