Hi Tom,Everything works fine now.but i receive e error when the pdf is to be open in the navigator.It is theServer Error500 - Internal server error.The pdf is well generate in the arcgisoutput and readable on the server but not throw IE 😞any idea??Thanks a lotDavid
http://swarcgis001/ArcGIS/rest/services/layout/MapServer/exts/PCHPrintSOE/printLayout?mapExtent={"xmin":145475,"ymin":165195.4174075015,"xmax":155475,"ymax":179545.4174075015,"spatialReference":{"wkt":"PROJCS[\"Belge_Lambert_1972\",GEOGCS[\"GCS_Belge_1972\",DATUM[\"D_Belge_1972\",SPHEROID[\"International_1924\",6378388.0,297.0]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Lambert_Conformal_Conic\"],PARAMETER[\"False_Easting\",150000.01256],PARAMETER[\"False_Northing\",5400088.4378],PARAMETER[\"Central_Meridian\",4.367486666666666],PARAMETER[\"Standard_Parallel_1\",49.8333339],PARAMETER[\"Standard_Parallel_2\",51.16666733333333],PARAMETER[\"Latitude_Of_Origin\",90.0],UNIT[\"Meter\",1.0]]"}}&printOutput={"toRemoveLayoutElements":["*"],"exportSettings":null,"mapRotation":0,"pageUnits":8,"resolution":100,"height":29.7,"borderWidth":[0.5,0.5,0.5,0.5],"width":21,"format":"pdf"}&mapElements=[]&layoutElements=[{"visible":true,"name":"myScaleBar","anchor":"bottomright","geometry":{"x":20.5,"y":0.5},"symbol":{"type":"pchScaleBar","barHeight":5}},{"visible":true,"name":"myScaleText","anchor":"topmid","geometry":{"x":10.5,"y":29.2},"symbol":{"type":"pchScaleText","separator":" : ","pageUnits":9,"backgroundColor":{"blue":255,"green":255,"alpha":255,"red":255},"mapUnits":8,"mapUnitLabel":"","pageUnitLabel":"","numberFormat":{"roundingOption":0,"roundingValue":3},"style":0}},{"visible":true,"name":"myLegend","anchor":"bottomleft","geometry":{"x":0.5,"y":0.5},"symbol":{"type":"pchLegend","showHeadings":false,"showLabels":true,"showLayerNames":true,"exceptionLayerNames":["ortho2010_white","Orthophotos2007","Orthophotos2004","Orthophotos2001","topo_100k","topo_050k","topo_020k","topo_005k"],"includeAllLayers":true,"legendColumns":1,"legendTitle":"Legend","legendBackground":{"type":"esriSFS","outline":null,"style":"esriSFSSolid","color":{"blue":255,"green":255,"alpha":255,"red":255}}}},{"visible":true,"name":"myLegend","anchor":"topright","geometry":{"x":20.5,"y":29.2},"symbol":{"type":"pchPictureEl AND http://swarcgis001/arcgisoutput/PrintTask_layout_1302766588558_layout.pdf
Could you restart your ArcGIS-Server services (not the mapservices).Is your "ortho2009" printSOE enabled? You just have to make the "layout" mapservice PrintSOE enabled.If it's enabled on the "ortho2009" mapservice, disable it.Tom
David,your url was cutted off. But I don't think that the problem is related to the SOEThe SOE is generating the pdf in the arcgisoutput folder.This seems to be something of your IIS configuration.Could you try to open an other file in the arcgisouput direcory as url from the IE (or create a simple html file in it to control the access)?If other files are working, you should check the file permissions.Eric,I'm looking for implementing "inch/feet" support.You are saying that 1 mapservice isn't displayed.Could you post the complete url and the mxd?Tom
