import arcpy arcpy.env.workspace = "c:/arcgis/" # Using a relative path mxd = arcpy.mapping.MapDocument('maps/template.mxd') #works mxd.save() #fails -> "AttributeError: MapDocObject: Unable to save. Check to make sure you have write access to the specified file and that there is enough space on the storage device to hold your document." mxd.saveACopy('template_copy.mxd')
import arcpy mxd = arcpy.mapping.MapDocument(r"C:\arcgis\maps\template.mxd") mxd.save()
That being said, in this instance I cannot replicate this behaviour you are seeing. I have tried in an ArcGIS session and through IDLE. I get an error at mxd object creation with an invalid MXD filename error. What Service Pack are you using?
''' c:/arcgis/ contents: template.mxd maps/template2.mxd ''' import arcpy, os os.chdir("c:/arcgis/") arcpy.env.workspace = "c:/arcgis/" # EXAMPLE 1 #use full path mxd = arcpy.mapping.MapDocument('c:/arcgis/maps/template2.mxd') mxd.saveACopy('template2_full_path_copy.mxd') #SUCCESSFULL #Need to reset env path os.chdir("c:/arcgis/") arcpy.env.workspace = "c:/arcgis/" # EXAMPLE 2 #use relative path but local source mxd = arcpy.mapping.MapDocument('template.mxd') mxd.saveACopy('template_relative_copy.mxd') #SUCCESSFULL # EXAMPLE 3 # Using a relative path, not local directory source mxd = arcpy.mapping.MapDocument('maps/template2.mxd') mxd.saveACopy('template2_copy_fails.mxd') #FAILS -> "AttributeError: MapDocObject: Unable to save. Check to make sure you have write access to the specified file and that there is enough space on the storage device to hold your document."
import os import arcpy os.chdir("C:/GIS/test") arcpy.env.workspace = "C:/GIS/Test" mxd = arcpy.mapping.MapDocument("point_2_line.mxd") mxd.saveACopy("ortho_test_rename/testing3.mxd")
Your chdir is what is doing it.
You are setting the relative path via python not the arcpy module.
I'd also recommend removing the trailing slashes at the end of your directory strings.
FYI I just tested and this works.
import os import arcpy arcpy.env.workspace = "C:/arcgis" mxd = arcpy.mapping.MapDocument("maps/template2.mxd") mxd.saveACopy("maps/testing7.mxd")
arcpy.mapping.MapDocument should immediately return an error when a relative path is used.
import os import arcpy arcpy.env.workspace = r"C:\GIS" mxd = arcpy.mapping.MapDocument(r"Test\point_2_line.mxd") mxd.saveACopy(r"Test\testing4.mxd")
Traceback (most recent call last): File "C:\GIS\Python\test_mxd_relative_path.py", line 7, in <module> mxd = arcpy.mapping.MapDocument(r"Test\point_2_line.mxd") File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 443, in __init__ assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename") AssertionError: Invalid MXD filename.
import os import arcpy os.chdir("C:/GIS") arcpy.env.workspace = r"C:\GIS" mxd = arcpy.mapping.MapDocument(r"Test\point_2_line.mxd") mxd.saveACopy(r"Test\testing4.mxd")
Traceback (most recent call last): File "C:\GIS\Python\test_mxd_relative_path.py", line 9, in <module> mxd.saveACopy(r"Test\testing4.mxd") File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\utils.py", line 181, in fn_ return fn(*args, **kw) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\_mapping.py", line 668, in saveACopy self._arc_object.saveACopy(file_name) AttributeError: MapDocObject: Unable to save. Check to make sure you have write access to the specified file and that there is enough space on the storage device to hold your document.
FYI I just tested and this works.import os import arcpy os.chdir("C:/GIS/test") arcpy.env.workspace = "C:/GIS/Test" mxd = arcpy.mapping.MapDocument("point_2_line.mxd") mxd.saveACopy("ortho_test_rename/testing3.mxd")
import arcpy, os, sys relPath = os.path.dirname(sys.argv[0]) mxd = arcpy.mapping.MapDocument(relPath + r"\project.mxd")
