I want to retain popupdata which i filled in it, when i close the popup coming from marker symbol , and again open it, my popup refreshed.??
Rajni,
You have a lot of unneeded redundancy in your code right now.
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>x<SPAN class="punctuation token">:</SPAN>evt<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> evt<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
This portion produces a point class in WKID 102100 (web mercator).
So there is no need for all this code:
<SPAN class="keyword token">var</SPAN> coords <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Lat/Lon "</SPAN> <SPAN class="operator token">+</SPAN> pt<SPAN class="punctuation token">.</SPAN>latitude <SPAN class="operator token">+</SPAN> <SPAN class="string token">" "</SPAN> <SPAN class="operator token">+</SPAN>pt<SPAN class="punctuation token">.</SPAN>longitude<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/* console.log(markertype+" "+comment);*/</SPAN> <SPAN class="keyword token">var</SPAN> p <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> longitude<SPAN class="punctuation token">:</SPAN> pt<SPAN class="punctuation token">.</SPAN>latitude<SPAN class="punctuation token">,</SPAN> latitude<SPAN class="punctuation token">:</SPAN> pt<SPAN class="punctuation token">.</SPAN>longitude<SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
So your code would look like this instead:
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>getmarkerclick<SPAN class="operator token">==</SPAN><SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> p <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>x<SPAN class="punctuation token">:</SPAN>evt<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> evt<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> changedSymbol <SPAN class="operator token">=</SPAN> <SPAN class="token function">changedsymbol</SPAN><SPAN class="punctuation token">(</SPAN>markertype<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> g <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> p<SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> changedSymbol<SPAN class="punctuation token">,</SPAN> attributes<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> newDevelopment<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"new marker"</SPAN><SPAN class="punctuation token">,</SPAN> state<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"new"</SPAN><SPAN class="punctuation token">,</SPAN> uniquetype<SPAN class="punctuation token">:</SPAN> markertype<SPAN class="punctuation token">,</SPAN> markerId<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"static"</SPAN><SPAN class="punctuation token">,</SPAN> comment<SPAN class="punctuation token">:</SPAN> comment <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//End view click</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I assume that "markertype" is a global var somewhere else in your code?
It is as simple as saving that text as an attribute to the graphic in your database and then when you recreate from the DB you you set the popup content to that attribute.
can you pls give one example, as i have multiple markers with popup, each have different popup values in its textbox. how can i differentiate between each of them
This is what the popup has always been designed to do. Show unique data based on the feature clicked. It does this using the features attributes.
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">addMarker</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> getmarker <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN> x<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"172.49720789367655"</SPAN><SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"-43.48319644512304"</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"This popup one content"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> x<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"172.50933147842412"</SPAN><SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"-43.48894119812065"</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN><SPAN class="string token">"This popup two content"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN> getmarker<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>marker<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> p <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> longitude<SPAN class="punctuation token">:</SPAN> marker<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN> latitude<SPAN class="punctuation token">:</SPAN> marker<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> g <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">geographicToWebMercator</SPAN><SPAN class="punctuation token">(</SPAN>p<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> textSymbol<SPAN class="punctuation token">,</SPAN> attributes<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> newDevelopment<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"new marker"</SPAN><SPAN class="punctuation token">,</SPAN> state<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"new"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> popupTemplate <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN> marker<SPAN class="punctuation token">.</SPAN>content <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> markerGL<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>g<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Sir,
I think you haven't understood, user will enter any value in textbox of popup and on save buton i am saving it in db, but when i again open that popup my popup do contain content body,but data gone entered by user???
actually i m looking for tht data to stay. Your example only change body of popup
