Unfortunately code didn't work. I modified it a little but still get exception on the CreateFeatureBuffer.I would like to give some explanation about what I'm trying to do. At the beginning I do not have any .mdb files. Only axMapControl on the form and MXD map file. Before opening this form, I'm trying to add a new layer to the existing map with some Points from the ADO.NET dataset.Using your code I'm trying to create an empty mdb file and then set up its parameters. For UID.Value I'm using GUID Id for AddData.Thank you
''** Create new FeatClass in PGDB pFeatureClass = pFWS.CreateFeatureClass(LayerName, _ pFields, _ pUID, _ Nothing, _ esriFeatureType.esriFTSimple, _ "Shape", "")
pFWS = pWorkspaceFactory.OpenFromFile(db_path, 0)
Function MakeGeoTrans(ByVal pFromSR As ISpatialReference, ByVal pToSR As ISpatialReference) As IGeoTransformation Dim pSRF As ISpatialReferenceFactory2 pSRF = New SpatialReferenceEnvironment Dim pGeoTrans As IGeoTransformation 'Set the transformation method you want (must be compatible with the input and output data sets) pGeoTrans = pSRF.CreateGeoTransformation(esriSRGeoTransformationType.esriSRGeoTransformation_NAD1983_To_WGS1984_1) pGeoTrans.PutSpatialReferences(pFromSR, pToSR) MakeGeoTrans = pGeoTrans End Function
Public Sub buildNewLayer(ByVal inDT As DataTable, _ ByVal LayerName As String) Dim pFeatureClass As IFeatureClass Dim pSpRFc As SpatialReferenceEnvironment pSpRFc = New SpatialReferenceEnvironment 'Setup Geographic CoordSys for GPS input pts Dim pGCS As IGeographicCoordinateSystem Dim pSpRefWGS As ISpatialReference pGCS = pSpRFc.CreateGeographicCoordinateSystem(esriSRGeoCSType.esriSRGeoCS_WGS1984) pGCS.SetDomain(-200, 200, -200, 200) pSpRefWGS = pGCS 'Setup Projected CoordSys for GPS output pts Dim pPCS As IProjectedCoordinateSystem Dim pSpRefNAD83 As ISpatialReference pPCS = pSpRFc.CreateProjectedCoordinateSystem(esriSRProjCSType.esriSRProjCS_NAD1983SPCS_FLWestFT) pPCS.SetDomain(420000, 690000, 880000, 1150000) pSpRefNAD83 = pPCS 'GeoTransformation declared Dim pGeoTrans As IGeoTransformation pGeoTrans = MakeGeoTrans(pSpRefWGS, pSpRefNAD83) '**Open the PGDB for temp layers Dim db_path As String = "C:\MyPGDB.mdb" 'name your PGDB here Dim pWS As IWorkspace Dim pFWS As IFeatureWorkspace Dim pWorkspaceFactory As IWorkspaceFactory pWorkspaceFactory = New ESRI.ArcGIS.DataSourcesGDB.AccessWorkspaceFactory pFWS = pWorkspaceFactory.OpenFromFile(db_path, 0) pWS = pFWS ' Set up a simple fields collection Dim pFields As ESRI.ArcGIS.Geodatabase.IFields Dim pFieldsEdit As ESRI.ArcGIS.Geodatabase.IFieldsEdit pFields = New ESRI.ArcGIS.Geodatabase.Fields pFieldsEdit = New ESRI.ArcGIS.Geodatabase.Fields pFieldsEdit = pFields Dim pField As ESRI.ArcGIS.Geodatabase.IField Dim pFieldEdit As ESRI.ArcGIS.Geodatabase.IFieldEdit pField = New ESRI.ArcGIS.Geodatabase.Field pFieldEdit = pField '*** set up geometry field *** Dim pGeomDef As ESRI.ArcGIS.Geodatabase.IGeometryDef Dim pGeomDefedit As ESRI.ArcGIS.Geodatabase.IGeometryDefEdit pGeomDef = New ESRI.ArcGIS.Geodatabase.GeometryDef pGeomDefedit = pGeomDef With pGeomDefedit .GeometryType_2 = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint .SpatialReference_2 = pSpRefNAD83 End With pField = New ESRI.ArcGIS.Geodatabase.Field pFieldEdit = pField pFieldEdit.Name_2 = "Shape" pFieldEdit.AliasName_2 = "Geometry" pFieldEdit.Type_2 = esriFieldType.esriFieldTypeGeometry pFieldEdit.GeometryDef_2 = pGeomDef pFieldsEdit.AddField(pField) '' create the object id field pField = New ESRI.ArcGIS.Geodatabase.Field pFieldEdit = pField pFieldEdit.Name_2 = "OBJECTID" pFieldEdit.Type_2 = esriFieldType.esriFieldTypeOID pFieldsEdit.AddField(pField) For i = 0 To inDT.Columns.Count - 1 pField = New ESRI.ArcGIS.Geodatabase.Field pFieldEdit = pField With pFieldEdit 'set all the properties according to the columns in the recordset .Length_2 = inDT.Columns(i).MaxLength .Name_2 = inDT.Columns(i).ColumnName .Type_2 = ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeInteger End With Dim ColName As String = inDT.Columns(i).ColumnName.ToString Dim dtColType As String = inDT.Columns(i).DataType.ToString If inDT.Columns(i).DataType.FullName.ToString = "System.Int32" Then pFieldEdit.Type_2 = ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeInteger ElseIf inDT.Columns(i).DataType.FullName.ToString = "System.String" Then pFieldEdit.Type_2 = ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeString ElseIf inDT.Columns(i).DataType.FullName.ToString = "System.Double" Then pFieldEdit.Type_2 = ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeDouble ElseIf inDT.Columns(i).DataType.FullName.ToString = "System.Decimal" Then pFieldEdit.Type_2 = ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeDouble ElseIf inDT.Columns(i).DataType.FullName.ToString = "System.DateTime" Then pFieldEdit.Type_2 = ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeDate End If pFieldsEdit.AddField(pField) Next i Try '**Check for existing FeatClass and delete if present Dim pExistingDs As ESRI.ArcGIS.Geodatabase.IDataset Dim pEnumDataset As IEnumDataset pEnumDataset = pWS.Datasets(esriDatasetType.esriDTFeatureClass) pExistingDs = pEnumDataset.Next Do Until pExistingDs Is Nothing If pExistingDs.Name = LayerName Then If pExistingDs.CanDelete Then pExistingDs.Delete() End If End If pExistingDs = pEnumDataset.Next Loop '** create a UID for simple features Dim pUID As ESRI.ArcGIS.esriSystem.UID pUID = New ESRI.ArcGIS.esriSystem.UID pUID.Value = UID_FEATURE ''** Create new FeatClass in PGDB pFeatureClass = pFWS.CreateFeatureClass(LayerName, _ pFields, _ pUID, _ Nothing, _ esriFeatureType.esriFTSimple, _ "Shape", "") Catch ex As Exception MsgBox(ex.ToString) End Try Dim pFeatCur As IFeatureCursor Dim pFeatBuf As IFeatureBuffer pFeatBuf = pFeatureClass.CreateFeatureBuffer pFeatCur = pFeatureClass.Insert(True) 'Add attributes to the FeatClass from ADO.NET Datasource Dim tmpPoint As IPoint Dim pGeo As ESRI.ArcGIS.Geometry.IGeometry Dim dtCol As DataColumn Dim dtColname As String Dim row As DataRow Try For i = 0 To inDT.Rows.Count - 1 row = inDT.Rows(i) If Not IsDBNull(row.Item("latitude")) And Not IsDBNull(row.Item("longitude")) Then '***add the rest of the attributes For Each dtCol In inDT.Columns dtColname = dtCol.ColumnName.ToString Dim dtColType As String = dtCol.DataType.ToString If Not IsDBNull(row.Item(dtColname)) Then pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = row.Item(dtColname) Else If dtCol.DataType.FullName.ToString = "System.Int32" Then pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CInt(0) ElseIf dtCol.DataType.FullName.ToString = "System.String" Then pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CStr("NA") ElseIf dtCol.DataType.FullName.ToString = "System.Double" Then pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CDbl(0.0) ElseIf dtCol.DataType.FullName.ToString = "System.Decimal" Then pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CDec(0.0) ElseIf dtCol.DataType.FullName.ToString = "System.DateTime" Then pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CDate(Now()) End If End If Next '*Add the new point tmpPoint = New ESRI.ArcGIS.Geometry.Point tmpPoint.PutCoords((CDec(row.Item("longitude"))), CDec(row.Item("latitude"))) '*Set the new point to match Projected CoordSys of SDE FeatureClass' pGeo = tmpPoint pGeo.SpatialReference = pSpRefWGS pGeo.Project(pSpRefNAD83) '*Create a point pGeo.SnapToSpatialReference() pFeatBuf.Shape = pGeo pFeatCur.InsertFeature(pFeatBuf) Else End If Next pFeatCur.Flush() Dim pDoc As ESRI.ArcGIS.ArcMapUI.IMxDocument Dim pMap As ESRI.ArcGIS.Carto.IMap pDoc = m_pApp.Document pMap = pDoc.FocusMap Dim pLayer As IFeatureLayer pLayer = New FeatureLayer pLayer.FeatureClass = pFeatureClass pLayer.Name = pFeatureClass.AliasName pDoc.AddLayer(pLayer) Catch ex As Exception MsgBox(ex.ToString) Me.Dispose() Finally DisposeCOMObject(pFeatCur) End Try pFeatBuf = Nothing pFeatureClass = Nothing End Sub
When you say "dataset", do you mean x/y values in an ADO.NET DataSet/DataTable?
Hi,I'm C# programmer and have some knowledge about working with ArcGIS Desktop 10. But I'm new at ArcObjects in C#. Can somebody give me an example, how I can add a new layer to existing MXD map in C# from XY table? Examples which I found before didn't work. Can I do this from dataset or we need to generate some extra files like TXT or XLS?Thank you
