With One way replication this is a known problem in 10.1 we are in contact with ESRI to resolve it but nothing yet.
With One way replication this is a known problem in 10.1 we are in contact with ESRI to resolve it but nothing yet.Until they do here is a workaround this seems to compress the tree to state 0 and move all delta edits to the base tables. We do this workaround on a weekly basis
HiSome of the system versions are required for the replica to continue to function properly, so writing a script to manually delete them would be risky. Determining what can be deleted depends on the generation numbers.We tested the issue with versions 9.3.1 and 10; the problem described has been resolved at version 10.CheersCheryl
HiThe problem may be another issue which we've recently discovered where the system sync version is not being deleted when synchronizing with Python script. Can you please let us know what your system configurarion is (i.e. database and ArcGIS/ArcSDE versions)? Would you be able to log an incident with esri support services so that we can investigate if this is what you are encountering?ThanksCheryl
9. - Run python script to synchronize the replica to the child database (which is supposed to synchronize to the child, delete the replica system version and create a new one based on the new default version of the database)
Can you describe this step more? Is this your own custom synchronize or are you using the Synchronize Changes gp tool? If the latter, the Synchronize Changes gp tool does not drop and recreate the replica as part of the synchronization.
9. - Run python script to synchronize the replica to the child database (which is supposed to synchronize to the child, delete the replica and create a new one based on the new default version of the database)
It sounds like you need acknowledgements from your child replica. Until you get those, the state tree would be pinned with those internal synch versions.
