Using the WGS 1984 Web Mercator Auxiliary Sphere coordinate system, how do I use the Geostatistical Analysis wizard to interpolate data from latitude and longitude points?
For your csv/Excel data, you can use the Add XY Data tool: File menu, Add Data, Add XY Data. After you browse to the file and select it, the tool will default the coordinate system to that of the maps. You probably instead want to override that and choose Geographic Coordinate System, North America, NAD 1983 (or North American 1983 depending on ArcGIS version).
Once the XY layer is created, you can right-click the layer and choose data, export data. In that tool, you can write the data out to a feature class, or a shapefile. There's an option to use the data's coordinate system (NAD 1983) or use the data frame's coordinate system.
To set the data frame's coordinate system to NAD 1983 UTM 18 North, choose projected coordinate system, UTM, NAD 1983. Or in the search box, type in 26918, which should select it for you.
Melita
Unless you are covering a large area, why are you using that coordinate system? In any event, you should project the data using an appropriate projection for your area. For 6 degree latitudinal widths, a UTM fits most bills, or Lambert Conformal Conic for larger EW extents.
I guess it depends on what you mean by large area, state of NY, but I wanted this because the map looks better, in my opinion, as it does not make my shape file look flattened.
I'm new to this, so you will have to explain what you mean as I don't understand.
Carter, this link provided by New York State cites several data sources as well as the coordinate system/projection that the data are available in. In a pinch use UTM Zone 18 (Data Management Tools, Projections and Transformations, Project tool NOT the define projection tool) and make it so since NY is 'mostly' in UTM zone 18. There are other state plane systems for NY, which are more accurate but their geographic is limited to a smaller area. So have a look at the link
carter,
Not quite clear on ‘to interpolate data from latitude and longitude points’.
Nevertheless, I assume that you want to spatially interpolate data from sparse points in geodetic coordinates (Long, Lat), for example, air pollution or soil moistures, etc.
If so, your measurements’ interpolation by Geostatistics technique can be done spatially in any projected or geodetic coordinate systems like local, UTM or WGS 1984 Web Mercator Auxiliary Sphere. To decide which coordinatesystem to use, it fully relies on the area and project you are working on (affecting your mapping accuracy only).
Secondly, if you want to make your interpolation successful, you are mostly required to ‘properly’ model spatial relationship among your measurements first, before taking interpolation, especially, with variant Kriging.
Thirdly, conduct the uncertainty analysis on your interpolation...
Have a look at Empirical Bayesian Kriging, which in 10,3, makes use of chordal distances if your data are in an unprojected coordinate system.
Or do your interpolation in an appropriate projected coordinate system and project the output to GCS, however, often the area is too large for this and that is why we introduced chordal distances.
-Steve
Ok let me explain this a bitter better. I can get it to plot the XY coordinates correctly (Image 1) but when I use the wizard to interpolate the data, the project ends up correct but in some other place really far away. (Image 2)
and if you right click the geostatistical layer, Properties->Source. What coordinate system is listed?
and then do the same for the input point feature class.
This is all its says
A csv file won't have a defined coordinate system. If you have added to arcmap using the File, add data, addxy data and it shows and then right click on the layer and export it to a shapefile at a minimum. Then if the coordinates are in decimal degrees use the Define Projection tool to establish its coordinate system (perhaps a GCS aka unprojected coordinate system, with a WGS or NAD83 datum). Once you have that done, then I would recommend projecting it so that you are working with planar coordinates rather than spherical ones. UTM for your area will do quite nicely for your area.
Then you are on to the task of interpolating, you should never use the defaults or only use them as a conscious decision to do so, paying particular attention to interpolation extents, cell size and parameters particular to your data and interpolation method.
So what as a non-project coordinate system would you suggest that is similar to WGS 1984 Web Mercator Auxiliary Sphere? The only reason I'm using this one is because it looks best.
GCS WGS 1984:
WGS 1984 Web Mercator Auxiliary Sphere:
See the difference?
I made my suggestion yesterday regarding projection options. If was hoping that something in that link would be useful should you wish to tie your data in with State data at some point. I would be less concerned about how your data looks and its projection that I would be about the sparseness of your data in the western half of your study area. But one issue at a time.
I'm aware of the sparseness in the western areas, I just used some sample data that was only Central NY/Northeast PA for an example. I just want to be able to interpolate my data into a coordinate system that doesn't flatten my shapefile like the GCS WGS 1984 system does or most of the other unprojected ones.
I have tagged Melita Kennedy who might be able to resolve your concerns on projections then, perhaps she has better suggestions.
Ok, thanks for your help.
From your plot, it looks that your sparse data already are well distributed in the map. However, you are not satisified with your interpolation results (by the Wizard). Correct?
If so, as said, nice to put more effort on modeling spatial relation among your data (rather than coordinate system), before using the Wizard.
Honestly, on our expereince, the GA Wizard in ArcGIS offers an easy workflow for some of users. But, mostly it is not case, if only using parameters by default.
If your data are still not mapped into the map 'properly', because you don't know the exact coordinate system of coodinates in the data from the CSV file, you can attach and share here.
So what you are say is that if I just do the data interpolation first then change the coordinate system it would work?
Sent from Outlook
Hi Carter,
When we display data that's using a geographic coordinate system, we treat the angular units (degrees) as if they're linear, so you get a stretched out look. It's really more stretched east-west because the meridians/longitude lines should be converging, not straight up-and-down. The web Mercator definition stretches north-and-south more so I think it looks more balanced to you.
Just about any projected coordinate system that's appropriate for the area will look more balanced to you. Here's NAD 1983 UTM zone 18 North, which Dan Patterson recommended (me too).
UTM uses transverse Mercator which is a conformal projection (so is Mercator used by web Mercator pcs) which maintains shapes and angles.
Ok...so how do I get my data to show up?
