<map wraparound180="true" initialextent="1336768.54628681 466504.867959491 1682954.44472431 713228.709105325" fullextent="1336768.54628681 466504.867959491 1682954.44472431 713228.709105325" top="40" wkid="3735" esrilogovisible="false"> <operationallayers> <layer label="Main AMS" type="dynamic" visible="false" url="http://10.2.0.20/ArcGIS/rest/services/MainAMS/MapServer"> <!-- Sanitary Meter Popup --> <sublayer id="1" popupconfig="popups/PopUp_SanitaryMeter.xml"/> <!-- Sanitary Network Structure Popup --> <sublayer id="4" popupconfig="popups/PopUp_SanitaryNetworkStructure.xml"/> <!-- Sanitary Manhole Popup --> <sublayer id="5" popupconfig="popups/PopUp_SanitaryManhole.xml"/> <!-- Sanitary Gravity Main Popup --> <sublayer id="6" popupconfig="popups/PopUp_SanitaryGravityMain.xml"/> <!-- Water Hydrant Popup --> <sublayer id="12" popupconfig="popups/PopUp_WaterHydrant.xml"/> <!-- Water Meter Popup --> <sublayer id="14" popupconfig="popups/PopUp_WaterMeter.xml"/> <!-- Water Control Valve Popup --> <sublayer id="15" popupconfig="popups/PopUp_WaterControlValve.xml"/> <!-- Water Network Structure Popup --> <sublayer id="18" popupconfig="popups/PopUp_WaterNetworkStructure.xml"/> <!-- Water Critical Main Popup --> <sublayer id="21" popupconfig="popups/PopUp_WaterCritialMain.xml"/> <!-- Water Main Popup --> <sublayer id="22" popupconfig="popups/PopUp_WaterMain.xml"/> <!-- Process Lift Station Popup --> <sublayer id="25" popupconfig="popups/PopUp_ProcessLiftStation.xml"/> <!-- Process Property Popup --> <sublayer id="26" popupconfig="popups/PopUp_ProcessProperty.xml"/> <!-- Process Control Valve Site Popup --> <sublayer id="27" popupconfig="popups/PopUp_ProcessControlValveSite.xml"/> <!-- Process EQ Basin Popup --> <sublayer id="28" popupconfig="popups/PopUp_ProcessEQBasin.xml"/> <!-- Process Pump Station Popup --> <sublayer id="29" popupconfig="popups/PopUp_ProcessPumpStation.xml"/> <!-- Process Water Storage Popup --> <sublayer id="30" popupconfig="popups/PopUp_ProcessWaterStorage.xml"/> <!-- Administrative HTE Location Point Popup --> <sublayer id="37" popupconfig="popups/PopUp_AdministravtiveHTE.xml"/> <!-- Administrative Pressure Zone Popup --> <sublayer id="38" popupconfig="popups/PopUp_AdministrativePressureZone.xml"/> <!-- Administrative Cleaning SubBasin Popup --> <sublayer id="39" popupconfig="popups/PopUp_AdministrativeCleaningSubBasin.xml"/> </layer> <layer label="Main PLL" type="dynamic" visible="false" url="http://10.2.0.20/ArcGIS/rest/services/MainPLL/MapServer"> <!-- Sanitary Meter Popup --> <sublayer id="1" popupconfig="popups/PopUp_SanitaryMeter.xml"/> <!-- Sanitary Network Structure Popup --> <sublayer id="4" popupconfig="popups/PopUp_SanitaryNetworkStructure.xml"/> <!-- Sanitary Manhole Popup --> <sublayer id="5" popupconfig="popups/PopUp_SanitaryManhole.xml"/> <!-- Sanitary Gravity Main Popup --> <sublayer id="6" popupconfig="popups/PopUp_SanitaryGravityMain.xml"/> <!-- Water Hydrant Popup --> <sublayer id="12" popupconfig="popups/PopUp_WaterHydrant.xml"/> <!-- Water Meter Popup --> <sublayer id="14" popupconfig="popups/PopUp_WaterMeter.xml"/> <!-- Water Control Valve Popup --> <sublayer id="15" popupconfig="popups/PopUp_WaterControlValve.xml"/> <!-- Water Network Structure Popup --> <sublayer id="18" popupconfig="popups/PopUp_WaterNetworkStructure.xml"/> <!-- Water Critical Main Popup --> <sublayer id="21" popupconfig="popups/PopUp_WaterCritialMain.xml"/> <!-- Water Main Popup --> <sublayer id="22" popupconfig="popups/PopUp_WaterMain.xml"/> <!-- Administrative HTE Location Point Popup --> <sublayer id="25" popupconfig="popups/PopUp_AdministravtiveHTE.xml"/> <!-- Proposed Water Control Valve Popup --> <sublayer id="28" popupconfig="popups/PopUp_WaterControlValve.xml"/> <!-- Proposed Water Hydrant Popup --> <sublayer id="29" popupconfig="popups/PopUp_WaterHydrant.xml"/> <!-- Proposed Water Main Popup --> <sublayer id="30" popupconfig="popups/PopUp_WaterMain.xml"/> <!-- Proposed Water Network Structure Popup --> <sublayer id="32" popupconfig="popups/PopUp_WaterNetworkStructure.xml"/> <!-- Proposed Sanitary Manhole Popup --> <sublayer id="37" popupconfig="popups/PopUp_SanitaryManhole.xml"/> <!-- Proposed Sanitary Gravity Main Popup --> <sublayer id="39" popupconfig="popups/PopUp_SanitaryGravityMain.xml"/> <!-- Proposed Sanitary Meter Popup --> <sublayer id="40" popupconfig="popups/PopUp_SanitaryMeter.xml"/> </layer> <!-- <layer label="Event Layers" type="dynamic" visible="false"--> <!-- url="http://10.2.0.20/ArcGIS/rest/services/EventLayers/MapServer">--> <!-- <sublayer id="3" popupconfig="popups/PopUp_FldOpsAllWO.xml"/>--> <!-- </layer>--> </operationallayers> <basemaps> <layer label="Satellite View" type="tiled" visible="false" alpha="1" url="http://10.2.0.20/ArcGIS/rest/services/SatelliteView/MapServer"> <!-- Montgomery County Parcel Popups --> <sublayer id="10" popupconfig="popups/PopUp_MontParcels.xml"/> <sublayer id="21" popupconfig="popups/PopUp_MontParcels.xml"/> <sublayer id="32" popupconfig="popups/PopUp_MontParcels.xml"/> <sublayer id="43" popupconfig="popups/PopUp_MontParcels.xml"/> <!-- Warren County Parcel Popups --> <sublayer id="9" popupconfig="popups/PopUp_WarrenParcels.xml"/> <sublayer id="20" popupconfig="popups/PopUp_WarrenParcels.xml"/> <sublayer id="31" popupconfig="popups/PopUp_WarrenParcels.xml"/> <sublayer id="42" popupconfig="popups/PopUp_WarrenParcels.xml"/> </layer> <layer label="Street View" type="tiled" visible="true" alpha="1" url="http://10.2.0.20/ArcGIS/rest/services/StreetView/MapServer"> <!-- Montgomery County Parcel Popups --> <sublayer id="16" popupconfig="popups/PopUp_MontParcels.xml"/> <sublayer id="34" popupconfig="popups/PopUp_MontParcels.xml"/> <sublayer id="52" popupconfig="popups/PopUp_MontParcels.xml"/> <sublayer id="70" popupconfig="popups/PopUp_MontParcels.xml"/> <sublayer id="88" popupconfig="popups/PopUp_MontParcels.xml"/> <!-- Warren County Parcel Popups --> <sublayer id="15" popupconfig="popups/PopUp_WarrenParcels.xml"/> <sublayer id="33" popupconfig="popups/PopUp_WarrenParcels.xml"/> <sublayer id="51" popupconfig="popups/PopUp_WarrenParcels.xml"/> <sublayer id="69" popupconfig="popups/PopUp_WarrenParcels.xml"/> <sublayer id="87" popupconfig="popups/PopUp_WarrenParcels.xml"/> </layer> </basemaps> </map>
private function loadNextBasemapLayer():void { var basemapLayerObject:Object = m_basemapLayers[m_basemapLayerIndex]; // configure popups, if any configureLayerRenderer(basemapLayerObject, false); } private function loadNextOpertionalLayer():void { var optLayerObject:Object = m_operationalLayers[m_operationalLayerIndex]; // configure pop-ups, if any configureLayerRenderer(optLayerObject, true); } private function loadNextOperationalOrBasemapLayer(isOperationalLayer:Boolean):void { if (isOperationalLayer) { // add layer to map after popups have been configured, if any var optLayerObject:Object = m_operationalLayers[m_operationalLayerIndex]; addLayerToMap(optLayerObject); m_optLayerTable.push(optLayerObject); m_operationalLayerIndex++; if (m_operationalLayerIndex < m_operationalLayers.length) { loadNextOpertionalLayer(); } } else { // add layer to map after popups have been configured, if any var basemapLayerObject:Object = m_basemapLayers[m_basemapLayerIndex]; addLayerToMap(basemapLayerObject); m_basemapLayerIndex++; if (m_basemapLayerIndex < m_basemapLayers.length) { loadNextBasemapLayer(); } } }
