Kenneth,Start out by taking a look at this document that outlines How to Deploy an ArcGIS Mobile Project with ArcGIS Desktop.Cheers,
I have found a solution for rasters without server now. You can add individual raster tiles to the mxd and they will come through into the mobilecache as an operational layer.However, a word of warning, if you have 1000 tiles, they come through as 1000 operational layers in mobile, there is no way to group them or bring them through as one catalog. If you have the time and space then creating a super tile for your area of interest works.Also, to solve this whole .wmpk extract workaround issue, another solution I have found is to copy the .wmpk and mobile cache folder onto the device into an empty folder eg \my documents\arcgismobile\newfolder\When the .wmpk extracts it sees the mobile cache folder already there and doesn't create a blank one instead
An alternative flow:Ability to create basemaps from static raster datasets is a real miss, I have searched and searched and cannot find a solution in 10, it seems the only options are either a streamed in ArcGISOnline basemap (which is not always suitable for field applications in rural areas and/or with non connected devices like a Juno SC) or getting hold of Server to create a basemap cache. 😞
arcpy.AddGlobalIDs_management(layerName)
This may be a bit of a junkie way of going about it, but its how I finally got some maps going on a HP iPAQ 212 mobile device using ArcGIS Mobile from the desktop
Is there anything in ArcTools that creates a mobile basemap layer to use in Arcmobile 10?I've read several different forum posts on this issue and it appears I'm not alone.Anyone?
