Hey all,
I've just noticed that if you rotate a MapView with an MapImageLayer on top, the MapImageLayer does not stay in sync with the views rotation. I.e. once you rotate off of 0 degrees, the MapImageLayer seems to rotate further each time and doesn't align with the view, util you go all the way back to 0 degrees.
This can be tested using the Javascript MapImageLayer sample: MapImageLayer - Toggle sublayer visibility | ArcGIS API for JavaScript 4.2
Just rotate the map.
Anyone else notice this? or have a workaround?
Cheers,
Jordan
