Hi.I've just started to learn ArcSDE, and I have a question about creating views. My database is Oracle Spatial and uses SDE. In my SDE-geodatabase there are several featureclasses; both polygons, polylines and points. I'm going to create a view based on some of the polyline featureclasses, with some of the attributes from the classes. I've create a geodatabasetable containing the featureinformation using SQL (Union). I'm trying to create the view using:"%SDEHOME%"\bin\sdetable -o create_view ^
-T DV_Points ^
-t "RiverPoints,dv_points" ^
-c "dv_points.description,dv_points.historic,dv_points.station,RiverPoints.SHAPE,RiverPoints.OBJECTID" ^
-w "RiverPoints.OBJECTID = dv_points.OBJECTID" ^
-i %1 -s %2 -u %3 -p %4
The query executes ok, and the view shows up in the geodatabase. But it's really slow. The view takes contains around 2000 features and it takes several minutes (10-30) to draw or query it. Is it right to use just one of the featuresclasses SHAPE-field (in the c-parameter), or should I use the shape-field from every featureclass?Regards, Torbjørn
