import arcpy, os arcpy.env.overwriteOutput = True #list of lists with values [X, Y, InterpolationValue] valLst = [ [20.0, 50.0, 345], [20.0, 51.0, 346], [20.5, 50.5, 347] ] #set up spatial reference and names prjFile = os.path.join(arcpy.GetInstallInfo()["InstallDir"], r"Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj") spatialRef = arcpy.SpatialReference(prjFile) tempWorkspace = "in_memory" outXYfc = "XY_FeatureClass" #create in_memory empty feature class arcpy.CreateFeatureclass_management(tempWorkspace, outXYfc , "POINT", "","","", spatialRef) #build temp FC path and add new field for values to interpolate tempFC = os.path.join(tempWorkspace, outXYfc) arcpy.AddField_management(tempFC, "InterpVal", "DOUBLE") #create insert cursor inCur = arcpy.InsertCursor(tempFC) #loop through main list, add values to cursor row and insert row for element in valLst: pnt = arcpy.Point(element[0], element[1]) row = inCur.newRow() row.Shape = pnt row.InterpVal = element[2] inCur.insertRow(row) del inCur, row #FOR TESTING: test if temporary feature class is OK #arcpy.CopyFeatures_management(tempFC, r"C:\tmp\Test.gdb\XYpoints")
