Using ArcGIS API for JavaScript 3.22 I am trying to add Snapping Function on adding Point to a Graphic Layer but bases on an existing ArcGISDynamicMapServiceLayer (snapping to Edges and Vertex in the ArcGISDynamicMapServiceLayer). but looks like the snapping is not functioning.
<SPAN class="operator token"><</SPAN>button id<SPAN class="operator token">=</SPAN><SPAN class="string token">"addP2P"</SPAN><SPAN class="operator token">></SPAN>Add Point To Points <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>button<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>button id<SPAN class="operator token">=</SPAN><SPAN class="string token">"addP2L"</SPAN><SPAN class="operator token">></SPAN>Add Point To Lines <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>button<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/ArcGISDynamicMapServiceLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/graphic"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/SnappingManager"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/keys"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN>
FeatureLayer<SPAN class="punctuation token">,</SPAN>
ArcGISDynamicMapServiceLayer<SPAN class="punctuation token">,</SPAN>
GraphicsLayer<SPAN class="punctuation token">,</SPAN>
Graphic<SPAN class="punctuation token">,</SPAN>
SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN>
SimpleLineSymbol<SPAN class="punctuation token">,</SPAN>
Color<SPAN class="punctuation token">,</SPAN>
SnappingManager<SPAN class="punctuation token">,</SPAN>
dojoKeys
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"topo"</SPAN><SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">88.158805</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">41.786075</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">18</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> P2PLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> P2LLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>P2PLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>P2LLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> DLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArcGISDynamicMapServiceLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver6.arcgisonline.com%2Farcgis%2Frest%2Fservices%2FWater_Network%2FMapServer" target="_blank">https://sampleserver6.arcgisonline.com/arcgis/rest/services/Water_Network/MapServer</A><SPAN>'</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>DLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> symbolPointJFlag <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleMarkerSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SQUARE<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#addP2P"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">one</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> addGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">addGraphic</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> sm <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SnappingManager</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
alwaysSnap<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
snapKey<SPAN class="punctuation token">:</SPAN> dojoKeys<SPAN class="punctuation token">.</SPAN>CTRL<SPAN class="punctuation token">,</SPAN>
tolerance<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
layerInfo<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
layer<SPAN class="punctuation token">:</SPAN> DLayer<SPAN class="punctuation token">,</SPAN>
snapToEdge<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
snapToVertex<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">var</SPAN> pgraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">,</SPAN> symbolPointJFlag<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
P2PLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>pgraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
