I have three fixed points and a number of lines I would like to draw that radiate out from each point. I have tried to use the bearing distance to line tool but it keeps failing for some reason and I'm not exactly sure how to draw my lines otherwise. I am using the angle field for the bearing and this is in degrees (I think...the values fall between 0 and 360). And my distance field is the 20yrSpread field which is in KM.
Any help is greatly appreciated...see the attached table.
