I've noticed that if I am doing simple addition, subtraction, or multiplication with two grids of different cell-sizes, and I set both the raster analysis cell size and the raster analysis mask to be that of the smaller grid, the output is mangled - it almost looks like it's incorporating the cell size of the LARGER grid into the mask somehow, but I don't really care, it's broken.Workaround is to not set the analysis mask.In the below image (Screenshot attached) you're looking at the results of adjusting four bathymetry MLLW datasets to NAVD88 by adding a Topography of the Sea Surface grid and subtracting a MLLW grid extracted from VDATUM. All grids are in same datum, VDatum grids are 0.0005 degrees, and the bathy rasters are from 0.5 to 4m resolution.. Also I can't believe that there isn't a better place to report bugs. These new forums are like a bowl of spaghetti someone dumped on the floor. If someone found a bug-reporting forum somewhere, please let me know.
