Are you sure all of the values in the field actually match your codes? If someone uses the Field Calculator on the field they could insert the domain description into the field directly and not the code, bypassing your domain restriction. The Field Calculator does not validate itself for any domain. These values would have no code and would only show the full value that is not in your domain. Only entries that actually were put in the field by the Domain drop down or that were calculated with valid domain codes would appear in the list as both a code and a description. So if a person calculated "Buried" into the field and the field allowed enough characters for that value, it would be inserted into the field without an error, despite the fact that only "Bur" is in the Domain to represent Buried and not the full word "Buried" that they just inserted. Another way this could have occurred is if you applied a Domain to a field that had the full description values spelled out and you did nothing to make them comply with your new domain codes before applying the domain. The fact that those existing values are not part of the Domain will not prevent you from applying the Domain, nor will it change the non-compliant values to comply with your domain.
You can find out if invalid values have been calculated into a domain controlled field by using the Validate Features option in the Editor menu. Also see the Validating features section and other aspects of domains in this help topic. Another way to see the invalid values and clean them up is to remove the domain and look at the raw values. If you actually see "Buried" then that value has to be changed to the "Bur" code as well as any other values that are not actually codes in the domain you are trying to apply.
The problem with using the Field Calculator is that there is no easy way to know what the codes actually are when calculating values into a domain controlled field from the Field Calculator dialog itself. You have to open the Select by Attribute dialog and get unique values for the field to see the code you are supposed to calculate into the field.
Nope. The problem is still there. Not sure if ESRI will ever fix it or if it is even possible to fix.
I am having this same problem in ArcMap 10.2.2. Did you ever find a solution?
April
Hi Wolseley,Whenever I do a Select by Attributes or Definition Query, I always see the [Domain Code] - [Domain Value]. I was wondering, is it possible to get a screenshot of your Coded Domain list? The answer might be there?The codes for the other domains, they aren't the same as the value by any chance are they?Cheers,Cory
