I am sure this is already out there but I could not find it so I thought I would share this code sample for storing and setting python toolbox tool parameter values using python pickles. I am not a programmer so any feedback for doing this a better way is always appreciated.
import arcpy, pickle, os, sys
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Pickle_Test"
self.alias = ""
# List of tool classes associated with this toolbox
self.tools = [Tool]
class Tool(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "Tool"
self.description = ""
self.canRunInBackground = False
def getParameterInfo(self):
"""Define parameter definitions"""
#set default values for tool parameters
scriptPath = sys.path[0]
test_val = pickle.load(open(scriptPath + "\\test_params.txt", "rb"))
#First parameter
param0 = arcpy.Parameter(
displayName="Input Feature Class",
name="in_fc",
datatype=["Feature Class"],
parameterType="Required",
direction="Input")
param0.value = test_val['param0']
params = [param0]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
def execute(self, parameters, messages):
"""The source code of the tool."""
test_val = {}
test_val = {"param0": parameters[0].valueAsText}
pickle.dump (test_val, open(scriptPath + "\\test_params.txt", "wb"))
return
