Hi All,
Don't know if this is the place to put this, but can't find a better venue!
I think I found a bug in the ArcPy CalculateField command that causes iPython to hang. I wrote about it here: arcgis desktop - arcpy, CalculateField: 'geoprocessing sys.stdout object' object has no attribute 'flush' - Geographic I…
Any advice on how to "submit" this to the arcpy team?
Thanks!
Nick
did you try changing the expression type to PYTHON_9.3 or is there a reason that you want the older geoprocessor object?
Hi Dan -- thanks for the suggestion! Unfortunately, the result appears is the same: I still get the same error.
What version of iPython are you using? I am running iPython 3.0.0 with ArcGIS 10.3, and I am able to use arcpy.CalculateField_management without any errors. There were 11 flush-related issues closed in iPython 3.0.0, maybe this was related to one of them.
I had been using 2.3, but just tried upgrading to 3.0.0 and am still having the issue.
I should also add I'm in Python 2.7.6. Did they update arcpy? (Also, any idea how to check arcpy version information? The module lacks a __version__ attribute...)
