Hi,I am using a Trimble ProXH GPS unit, and I have it hooked up to my laptop via serial or Bluetooth.I am able to collect data perfectly on ArcGIS Mobile 10 Out-of-the-box solution.The important thing for the ProXH GPS is to be configured in NMEA output as opposed to TSIP.I used GPS Controller to configure the ProXH.I know you mentioned that everything seems to be ok, but with GPS Controller, you can output the raw GPS data in NMEA and select which NMEA strings you want to output. You may be missing a NMEA string that you need for PDOP.Hope this helps.
We installed FRANSON GPS GATE on our Tablet and it could locate our GPS and ArcMobile can then collect the GPS stream. If we disable the FRANSON GPS software ArcMobile can't locate the GPS.
I have two GPS devices that I use.The Trimble ProXH, and I use GPS Controller to configure NMEA output and a serial to USB converter with prolific drivers. I have no problem getting NMEA strings in ArcGIS Mobile.Then we bought Garmin Montana 650 GPS Navigation systems, they look like a large smart phone and I also use FRANSON GPS GATE, and I believe we installed the Garming USB drivers beforehand.Overall, the Garmin Montana was superior to the Trimble ProXH in both urban and rural tests. The ProXH will not work in urban areas causing ArcGIS Mobile to constantly throw an error, saying "Would you like to reconnect", whereas the Garmin can guestimate your location in urban areas and will allow ArcGIS Mobile to continue to collect data.I wish I knew all of this when I first started building with ArcGIS Mobile, because I have spent countless months on trying to figure out GPS/NMEA problems with the Trimble ProXH. Now that we have switched to the Garmin Montana series, my work-life is a lot easier.I hope this helps others!
