Kudos! Over a decade later and this solution was still exactly what I was looking for! I had tried with raster but per your suggestion, tried multipatch and it worked perfectly.
Thanks, Eric!
Justin Forget the Construct Site Lines tool. All we need to do is run Points to Line (using your Sort ID field as the Sort Field parameter), and Splite Line at Vertices. I do want to point out your original points are in geographic coordinates, and the z value (altitude?) is definitely not in units of DD. So what I did was make an assumption that altitude was meters, and projected the points to UTM meters so that x,y,z were all the same units. Then I created the lines and split them so each would be a unique record. The attached zip file has the lines for you to check.Eric
Though this is a very old post, I was wondering if there was a way to do this in ArcEditor 9.3.2. I've got the visualization working well enough but I'd really like to be able to get the intersection points for my 3D lines and my surface. Thank you.
