Peter and Mike,
I am trying to do the Extract Multi-values to Points tool as well. I am using version 10.8.1. I am getting two errors ( 010560 and 010167) when I try to run this tool. I have tried the above solutions but I am still getting both of these errors. Can you help? Thanks in advance!
Hi Mike,I ended up using the help from an ESRI representative through our service contract because I couldn't fiugure out what the issue was with my data either. They were great and we got the issue figured out within a day. The rep told me that within my data "A column may not start with a number or underscore. Here is a document explaining naming conventions http://resources.arcgis.com/content/kbase?fa=articleShow&d=23087. Note: The column names are no longer an issue at ArcGIS 10. If you have access to a machine which has ArcGIS 10 installed, you would be able to run Extract Values to Points without any issue." I hope that this helps.
