Hello all, I need to export my map as tiff, jpeg or pdf files. How should I do? Thanks a lot!
Juan - good question - perhaps this may help:
http://doc.arcgis.com/en/arcgis-online/share-maps/manage-hosted-layers.htm
Allow data exports
You can export a comma-separated value (CSV) file, shapefile, or file geodatabase feature class from any layer in a hosted feature layer if one of the following is true:
This setting can be changed by clicking Edit on the hosted feature layer's item details page and clickingAllow others to export to different formats under the Properties list.
Only nonspatial attributes are exported to a CSV file when you export a line or polygon layer from a hosted feature layer. When you export a point layer to a CSV file, latitude and longitude values for the points are exported.
Follow these steps to export a CSV file, shapefile, or file geodatabase containing a feature class from a layer:
hi Juan,
You might want to supply a but more information, such as, are you logged into an organizational account, a free account, or the public arcgis.com ? the ability and format of output can be controlled but the creator of the map, to some degree, but if you are viewing someone else map, or a public map, you may not be able to, depending on how it is presented.
So, if you can supply a few more details on what you are trying to print, it will help others that maybe can help.
Thanks Rebecca. Sorry for not providing details, I am a beginner... I have a free account, and I am creating my own maps using public information as well as shapefiles we have uploaded too. These maps need to be exported and printed in high res.
Are you working on the Argis Online or Desktop?
