/** * Created by Rob Chouinard * * Free to use and destroy! * Requires Silverlight API 3.1+ and ArcGIS Server 10.1 SP1+ * Use is similar to ESRI.ArcGIS.Client.Tasks.QueryTask **/ using System; using System.ComponentModel; using System.Collections.Generic; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Tasks; namespace ESRI.ArcGIS.Extensions { public class QueryDistinctTask { ArcGISWebClient webClient = null; /// <summary> /// Initializes a new instance of the <seealso cref="QueryDistinctTask"/> class. /// </summary> /// <param name="Url">The URL of the task.</param> public QueryDistinctTask(string Url = "") { this.Url = Url; } #region Properties /// <summary> /// If true, adds a timestamp parameter ("_ts") to the request to prevent it from being loaded from the browser's cache. /// </summary> public bool DisableClientCaching { get { return disableClientCaching; } set { if (disableClientCaching != value) { disableClientCaching = value; OnPropertyChanged("DisableClientCaching"); } } } bool disableClientCaching = false; /// <summary> /// Gets a value that indicates whether a Web request is in progress. /// </summary> public bool IsBusy { get { if (webClient != null) return webClient.IsBusy; else return false; ; } } /// <summary> /// Gets or sets the URL to proxy the request through. /// </summary> public string ProxyURL { get { return proxyURL; } set { if (proxyURL != value) { proxyURL = value; OnPropertyChanged("ProxyURL"); } } } string proxyURL; /// <summary> /// Gets or sets the last query result. /// </summary> public FeatureSet LastResult { get { return lastResult; } private set { if (lastResult != value) { lastResult = value; OnPropertyChanged("LastResult"); } } } FeatureSet lastResult; /// <summary> /// Gets or sets the URL of the task. /// </summary> public string Url { get { return url; } set { if (url != value) { url = value; OnPropertyChanged("Url"); } } } string url; #endregion #region Events /// <summary> /// Occurs when the query completes. /// </summary> public event EventHandler<QueryDistinctEventArgs> ExecuteCompleted; /// <summary> /// Occurs when the query completes and fails. /// </summary> public event EventHandler<AsyncCompletedEventArgs> Failed; /// <summary> /// Occurs when a property value changes. /// </summary> public event PropertyChangedEventHandler PropertyChanged; #endregion #region Public Methods /// <summary> /// Cancels a pending asynchronous operation. /// </summary> public void CancelAsync() { if (webClient != null) webClient.CancelAsync(); } /// <summary> /// Executes a query against an ArcGIS Server map layer. The result is returned as a FeatureSet. If the query is successful, the <seealso cref="QueryDistinctTask.ExecuteCompleted"/> event is raised with the result. A FeatureSet contains an array of Graphic features without geometery. This array will not be populated if no results are found. /// </summary> /// <param name="query">Specifies the attributes filter of the query.</param> /// <param name="userToken">A user-defined object that is passed to the method invoked when the asynchronous operation completes.</param> public void ExecuteAsync(QueryDistinct query, object userToken = null) { webClient = new ArcGISWebClient(); webClient.DisableClientCaching = DisableClientCaching; webClient.ProxyUrl = ProxyURL; webClient.DownloadStringCompleted += DownloadStringCompleted; string extendedUrl = Url; if (!Url.EndsWith("/")) extendedUrl += "/"; extendedUrl += "query"; if (!webClient.IsBusy) webClient.DownloadStringAsync(new Uri(extendedUrl), GetParameters(query), ArcGISWebClient.HttpMethods.Auto, userToken); else { throw new Exception("The web client is busy processing it's current task. \nWait for the current process to complete before processing another request."); } } #endregion #region Private Methods IDictionary<string, string> GetParameters(QueryDistinct query) { IDictionary<string, string> parameters = new Dictionary<string, string>(); if (query.Where != null && query.Where.Length > 0) parameters.Add("where", query.Where); else if (query.Text != null) parameters.Add("text", query.Text); parameters.Add("outFields", string.Join(",", query.OutFields)); // Return all of the fields. parameters.Add("returnGeometry", "false"); // Do not include the geometry coordinate values. parameters.Add("returnDistinctValues", "true"); // Since that is what we are after. parameters.Add("f", "json"); // Get the results back in the 'pretty' JSON format. return parameters; } void DownloadStringCompleted(object sender, ArcGISWebClient.DownloadStringCompletedEventArgs e) { if (e.Error != null || e.Cancelled) { OnFailed(new AsyncCompletedEventArgs(e.Error, e.Cancelled, e.UserState)); return; } if (e.Cancelled) return; try { FeatureSet featureSet = FeatureSet.FromJson(e.Result); int count = featureSet.Features.Count; lastResult = featureSet; QueryDistinctEventArgs queryEventArgs = new QueryDistinctEventArgs(featureSet) { UserState = e.UserState }; OnExecuteCompleted(queryEventArgs); } catch (Exception) { try { ServiceException se = ServiceException.FromJson(e.Result); OnFailed( new AsyncCompletedEventArgs(se, e.Cancelled, e.UserState)); } catch (Exception) { OnFailed( new AsyncCompletedEventArgs( new Exception("Failed to parse featureSet from json.\nCheck your URL and query."), e.Cancelled, e.UserState) ); } } } void OnFailed(AsyncCompletedEventArgs asyncCompletedEventArgs) { if (Failed != null) Failed(this, asyncCompletedEventArgs); } void OnPropertyChanged(string Name) { if (PropertyChanged != null) PropertyChanged(this, new PropertyChangedEventArgs(Name)); } void OnExecuteCompleted(QueryDistinctEventArgs queryEventArgs) { if (ExecuteCompleted != null) ExecuteCompleted(this, queryEventArgs); } #endregion } public class QueryDistinct { public OutFields OutFields { get; set; } public string Text { get; set; } public string Where { get; set; } public QueryDistinct() { OutFields = new OutFields(); } } public class QueryDistinctEventArgs : EventArgs { public FeatureSet FeatureSet { get; private set; } public object UserState { get; set; } public QueryDistinctEventArgs(FeatureSet featureSet) { FeatureSet = featureSet; } } }
