Where can the settings be found to make sure Global IDs are maintained through processing (specifically Append) in ArcMap 10.5?
Preserve global ids is an environment parameter, so you set it through the tools Environment settings
Preserve Global IDs (Environment setting)—Geoprocessing | ArcGIS Desktop
This is for ArcGIS pro, but a similar setting in arcmap
see way at the bottom
Append—Help | ArcGIS Desktop
Thanks Dan. I am aware of the page you posted and I have combed the environments settings both under the Geoprocessing menu and can't find the place to check mark to maintain the Global IDs. I have found maintain attachments, but that is the closest I found. Am I just looking in the wrong place for the box?
Tia,
I don't use ArcMap any more, but it is via the environments setting on the actual if memory serves.
In pro, they move the environment settings to the top of the tool rather than at the bottom, so it is easier to find and more likely to be used.
Good to know, might have to see if I can run this in Pro. Thank you
Unfortunately and wondering why those options are not available anymore but for the Append tool in Pro it is not possible to use the environment settings output coordinates. Even when you set them the tool is is not one of the tools that can use these setting.
forcing into a unnecessary workaround proces!!!
