using System; using System.Collections.Generic; using System.ComponentModel.Composition; using System.Linq; using System.Windows; using System.Windows.Browser; using System.Windows.Controls; using System.Windows.Interactivity; using System.Windows.Media.Animation; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Extensibility; using ESRI.ArcGIS.Client.Geometry; namespace Behavior.Startup { [Export(typeof(Behavior<Map>))] [DisplayName("Enable application to start with initial extent")] [Category("Behaviors")] [Description("Enable application to start with initial BBOX extent")] public class StartupExtentBehavior : Behavior<Map> { #region Behavior Overrides protected override void OnAttached() { base.OnAttached(); MapApplication.Current.Map.Loaded += Map_Loaded; } protected override void OnDetaching() { MapApplication.Current.Map.Loaded -= Map_Loaded; } #endregion #region Events void Map_Loaded(object sender, RoutedEventArgs e) { // BBOX in format: BBOX=minx,miny,maxx,maxy: Bounding box corners (lower left, upper right) in SRS units. if (HtmlPage.Document != null && HtmlPage.Document.QueryString.Count > 0 && HtmlPage.Document.QueryString["BBOX"] != null) { double[] bbox = new double[4]; var val = HtmlPage.Document.QueryString["BBOX"].ToString(); var dd = val.Split(',').Select(x => double.Parse(x)); int i = 0; foreach (double d in dd) { bbox = d; i++; } Envelope newExtent = new Envelope(bbox[0], bbox[2], bbox[2], bbox[3]); MapApplication.Current.Map.ZoomTo(newExtent); } } #endregion } }
