Imports System.Threading Imports System.Net Module agsServicesWakeUp Sub Main() readHTML() End Sub Private Sub readHTML() Try Dim objWebClient As New WebClient objWebClient.UseDefaultCredentials = True Dim aRequestHTML() As Byte = objWebClient.DownloadData("http://yourservername/ArcGIS/rest/services") 'Change to your server Dim counter As Integer = 0 Dim html As String = "" Do While counter < aRequestHTML.Length html += Chr(aRequestHTML.GetValue(counter)) counter = counter + 1 Loop Dim serviceFolderArray() As Object = {} Dim i As Integer = 0 Dim j As Integer = 1 Dim count As Integer = 0 Do While i < html.Length i = InStr(j, html, "/ArcGIS/rest/services/") If i > 0 Then j = InStr(i, html, ">") - 1 Dim serviceFolder() As String = {html.Substring(i - 1, j - i)} Array.Resize(serviceFolderArray, count + 1) Array.ConstrainedCopy(serviceFolder, 0, serviceFolderArray, count, 1) count = count + 1 i = j Else i = 0 j = 1 count = 0 Exit Do End If Loop Dim k As Integer = 0 Dim servicesArray() As Object = {} Do While k < serviceFolderArray.Length objWebClient.UseDefaultCredentials = True Dim serviceRequestHTML() As Byte = objWebClient.DownloadData("http://yourservername" + serviceFolderArray(k).ToString) 'Change to your server name counter = 0 html = "" Do While counter < serviceRequestHTML.Length html += Chr(serviceRequestHTML.GetValue(counter)) counter = counter + 1 Loop Do While i < html.Length i = InStr(j, html, serviceFolderArray(k).ToString + "/") If i > 0 Then j = InStr(i, html, ">") - 1 Dim service() As String = {html.Substring(i - 1, j - i)} Array.Resize(servicesArray, count + 1) Array.ConstrainedCopy(service, 0, servicesArray, count, 1) count = count + 1 i = j Else i = 0 j = 1 Exit Do End If Loop k += 1 Loop callURL(servicesArray) callURL(servicesArray) Catch ex As Exception MsgBox(ex.Message) End Try End Sub Private Sub callURL(ByVal servicesArray As Object, Optional ByVal sleep As Integer = 100) Dim i As Integer = 0 Dim webApp webApp = CreateObject("InternetExplorer.Application") webApp.Visible = False Do While i < servicesArray.Length Console.WriteLine("http://yourservername" + servicesArray(i).ToString) 'Change to your server name webApp.Navigate("http://yourservername" + servicesArray(i).ToString) 'Change to your server name Thread.Sleep(sleep) i += 1 Loop webApp.quit() webApp = Nothing End Sub End Module
