Would it be possible to share the roadmap of Experience builder so that we can have an overview of what's coming on and when?
Thank you in advance for your answer.
Regards,
Jérôme
Peder,
We do plan to support more variables in Theme including the font size and custom font. Thanks for your suggestions.
I'd love to see the ability to use custom fonts in the ArcGIS online-version of ExB. Ideally it would be great to have full control over all theme variables including fonts in the builder, like in the developer edition.
This would allow us to build apps that integrate better with existing websites, and to build stand-alone apps using customer-specific themes and branding.
Peder
Jerome,
Thanks for the clarification and thoughtful proposals. Regarding new features, #1 is not under the consideration as it is recommended to do so in Map Viewer. You may create a custom widget. #2 you may add or remove a layer on the fly like what the Add Data widget does in WAB, then save the added layers with the web map out as a new web map. It is unlikely to allow you to remove the layers from the existing map. #3 is on the road map once JSAPI 4 and new Map Viewer start to support it. #4 Saving map is doable but loading a new map will break the widgets dependent on map layers as stated in one of the comments above. #5 need to have further evaluation.
Regarding migration of WAB OOTB widgets to ExB, #1 is a common workflow which should be doable. #2 is under our consideration of consolidating functions in one widget. #3 Could you help articulate it with a user case? #4 is similar to #1. #5- Analysis widget is not part of JSAPI 4 yet, once available, we plan to wrap it in ExB. #6 JSAPI 4 may have the feature table ready around UC. We will wrap it in ExB once available.
Hope this helps,
Jianxia
Glad to see these custom widgets addressing popular requests for Web AppBuilder.
Annina,
Thanks for your feedback. From my understanding, you use the Embed widget by passing the app URL to display the app in ExB. Further, you want apps to talk to each other so the embedded app can pass information to other widgets in ExB. This workflow makes sense and an enhancement has been submitted. May I ask you what type of the app is embedded in your case?
For the Survey widget, could you help articulate your use case to automatically populate a survey with fields that are from different layers? Currently we can populate a survey with multiple fields from one layer on the map.
Jerome and Annina,
Thank you so much for your feedback. One big item in the near road map is to integrate Experience Builder (ExB) in ArcGIS Enterprise 10.8.1 planned to be available in July. In addition, to build a robust foundation for the future, we put efforts on the product improvement for the upcoming July release, including ability to copy, paste, and rotate the widget, performance optimization, UI and UX improvement, support for more data type, support for attachments and feature layer symbol in the Image widget, display Arcade and related table in the Feature Info widget, as well as new Bookmark widget, etc. Please noted that the plan is subject to change.
Your suggestions and feedback are valuable. I will reply to your comments separately.
Jianxia Song,
In addition to my previous message, we did develop (or are currently developping) some custom widget in WebAppbuilder (list below) that could be usefull for many user to have at least in Experience Builder. If we do provide the code, could you propose to translate that into an Experience Builder Widget that could be propose as standard widget in the product?
List of new widget or widget extension developped
Thank you in advance for your collaboration
Dear Jianxia Song,
Thank you for your answer. Here are some of the main new feature or conversion of widget existing in WAB that would drastically improve our usage of ExB. Most of the new features below have been requested for a long time by WAB users and I guess WAB Widget I have listed below are probably the one which are the most used.
New Features:
Translation/rewriting of WAB Widget
Thanks a lot in advanced for your feedback and @ your disposal for any questions and/or precisions.
I'd like to know what widgets are going to be included in the next release. I'd be interested in hearing if there currently is, or will be in the future, capability of gathering data from the website used in the URL widget for use in other widgets in ExB. For example, since WAB currently has a lot of widgets, I am using the URL widget in ExB to show an app I created with WAB. But I want to be able to query information in there and display/add to a text box or survey in ExB. Speaking of surveys...I really need the capability of autopopulating a survey with data from multiple fields from multiple layers (and from my web app I'm embedding). Currently all you can add is one field from one layer.
Thanks! ExB is pretty cool, and I'm excited to see it grow!
We are working on the road map for the next release. What features you'd like to see in the near future? Thanks,
Hi Jerome,
Thanks for the inquiry about Experience Builder and the roadmap. I adding our product manager to this discussion Jianxia Song.
Cheers,
David
