map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
function showResults(idResults, evt) { for (var i = 0, il = idResults.length; i < il; i++) { var graphic = idResults; graphic.feature.setInfoTemplate(sustaintemplate); } map.infoWindow.setContent(updatePopup(graphic)); //map.graphics.clear(); //Set the infoWindow to open at the top right of the point at all times map.infoWindow.setFixedAnchor(esri.dijit.InfoWindow.ANCHOR_UPPERRIGHT); //Determine the upper right, and center, coordinates of the map var maxPoint = new esri.geometry.Point(map.extent.xmax, map.extent.ymax) var centerPoint = new esri.geometry.Point(map.extent.getCenter()); //Convert these to screen coordinates var maxPointScreen = map.toScreen(maxPoint); var centerPointScreen = map.toScreen(centerPoint); //Subtract the size of the infoWindow, including a buffer. //This will show whether the infoWindow would spill out of the current view. var xDiff = Math.abs(maxPointScreen.x - evt.screenPoint.x) - 470; var yDiff = Math.abs(maxPointScreen.y - evt.screenPoint.y) - 490; //If required, recalculate a new centerpoint which accounts for the infoWindow if (xDiff < 0) { centerPointScreen.x -= xDiff; } if (yDiff < 0) { centerPointScreen.y += yDiff; } //Pan the map to the new centerpoint (in Map coordinates) centerPoint = map.toMap(centerPointScreen); map.centerAt(centerPoint); //Display the infoWindow at the original point clicked map.infoWindow.show(evt.screenPoint, esri.dijit.InfoWindow.ANCHOR_UPPERRIGHT); }
Thanks Alex, that actually saved me a lot of time. I adapted it to a function which measures how close a DOMElement is to the map extent boundaries:
getElementDistanceFromExtent: function(element) { if (!$ic.isNotNullObject(element)) return false; var posElementInfo = dojoDomGeometry.position(element); var maxPoint = new Point(this.map.extent.xmax, this.map.extent.ymax); var minPoint = new Point(this.map.extent.xmin, this.map.extent.ymin); var centerPoint = new Point(this.map.extent.getCenter()); var maxPointScreen = screenUtils.toScreenGeometry(this.map.extent, this.map.width, this.map.height, maxPoint); var minPointScreen = screenUtils.toScreenGeometry(this.map.extent, this.map.width, this.map.height, minPoint); var distXmax = maxPointScreen.x - (posElementInfo.x + posElementInfo.w); var distXmin = posElementInfo.x - minPointScreen.x; var distYmax = minPointScreen.y - (posElementInfo.y + posElementInfo.h); var distYmin = posElementInfo.y - maxPointScreen.y; return { distXmax: distXmax, distXmin: distXmin, distYmax: distYmax, distYmin: distYmin }; }
