Unfortunately, Collector has stopped.
Can you share the service that is causing the issue?ThanksRuss
Without being able to really see the dataset and the logs coming from the app it is a little difficult to comment on. Can you share the service or XML schema output from your gdb for this layer and I can take a look at it.ThanksRuss
You can try using an app like Catlog: https://play.google.com/store/apps/details?id=com.nolanlawson.logcat orYou can download the Android SDK and try running this tool with the device plugged into your computer:http://developer.android.com/tools/debugging/ddms.html
That is strange. I will try and repro it with a test dataset.Russ
Update failed Updates could not be sent
Did you enable sync on that service?
Depending on the version of desktop you are using you should see it when you are publishing the feature service and you are enabling the capabilities for the service. And the Collector does not fully support geometric networks currently.Russ
Are you able to perform the same edits in the web map and see that data sync with your database? Also try refreshing you web page after you make the edit change to see if it is still there in the web map.I am checking out my network test now and will update the thread when I am done. Update:I did a quick test with a sample network and my edits submitted without any issue.Russ
This could mean there is an issue with the service and the server is not accepting the features.Russ
