<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <fx:Script> <![CDATA[ import com.esri.ags.events.LayerEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.layers.ArcGISDynamicMapServiceLayer; [Bindable] private var layerCount:int = 0; protected function myURL_creationCompleteHandler(event:Event):void { if(!MyML.getLayer(myURL.selectedItem)){ var myDynamicService:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(); myDynamicService.url = "http://gis-server/ArcGis/rest/services/" + myURL.selectedItem + "/MapServer"; myDynamicService.name = myDynamicService.id = myURL.selectedItem; myDynamicService.addEventListener(LayerEvent.LOAD, setMapCenter); MyML.addLayer(myDynamicService); layerCount++; }else{ setMapCenter(null); } } private function setMapCenter(evt:Event):void { switch(myURL.selectedItem) { case "Raichur":{ MyML.centerAt(new MapPoint(76.90,16.12)); break; } case "Yadgir":{ MyML.centerAt(new MapPoint(76.88,16.89)); break; } } } ]]> </fx:Script> <esri:Map id="MyML" width="100%" height="100%" /> <s:DropDownList id="myURL" selectedIndex="0" creationComplete="myURL_creationCompleteHandler(event)" change="myURL_creationCompleteHandler(event)"> <s:ArrayList> <fx:String>India</fx:String> <fx:String>Africa</fx:String> </s:ArrayList> </s:DropDownList> <s:Label text="{layerCount}" x="200" y="3" /> </s:Application>
protected function myURL_creationCompleteHandler(event:FlexEvent):void { var myDynamicService:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(); myDynamicService.url = "http://gis-server/ArcGis/rest/services/" + myURL.selectedItem + "/MapServer"; myDynamicService.name = myURL.selectedItem; MyML.addLayer(myDynamicService); switch(myURL.selectedItem){ case "India":{ MyML.centerAt(new MapPoint(70.0,6.0)); break; } } case "Africa":{ MyML.centerAt(new MapPoint(80.0,12.0)); break; } }
Ismail, You can not do it the way you are trying, because the mapservice will likely always get created before the myURL component.Try this:<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <fx:Script> <![CDATA[ import com.esri.ags.events.LayerEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.layers.ArcGISDynamicMapServiceLayer; import mx.events.FlexEvent; protected function myURL_creationCompleteHandler(event:FlexEvent):void { var myDynamicService:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(); myDynamicService.url = "http://gis-server/ArcGis/rest/services/" + myURL.selectedItem + "/MapServer"; myDynamicService.name = myURL.selectedItem; MyML.addLayer(myDynamicService); } ]]> </fx:Script> <esri:Map id="MyML" width="100%" height="100%" /> <s:DropDownList id="myURL" selectedIndex="0" creationComplete="myURL_creationCompleteHandler(event)"> <s:ArrayList> <fx:String>Highway</fx:String> </s:ArrayList> </s:DropDownList> </s:Application>Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
